Block coupling solvers for multi-region problems |
June 14, 2022, 21:05 |
Rep Power: 7 |
Hi
I am referring to my recent post Discontinuous conductivities in heat transfer From the lack of responses, I conclude that there are no block coupling solvers involving fields over adjacent meshes. And even after reading code from blockLduMatrix I really don't know where to start if I have to do it on my own. Therefore, this thread is a request to add such solvers to open-foam-extend. I am sure there are individuals in the OpenFOAM community that are much more capable than little me and who could handle this task. It would be greatly appreciated since I have hit a roadblock. Regards to all |
June 19, 2022, 14:14 |
Rep Power: 7 |
I'll give you a hint though.
The forebear method ( a hack that I believe was specific conjugate heat transfer only) is to be found on p 10 of Implicit solution techniques for coupled multi-field problems – Block Solution, Coupled Matrices Advanced Training at the OpenFOAM Workshop Jun 6 2010 and, the generalized version is to be found on p 43 of Block-Coupled Simulations Using OpenFOAM 6th OpenFOAM Workshop 13-16 June 2011 Therefore, probably the latter approach is the way out, together with the appropriate boundary condition that is desired at the interface between the meshes. So I think that after more than 3 years, I finally see light at the end of the tunnel. But to be forthright, I'm still surprised that nobody shows any interest in this kind of block coupling. Anyhow, thanks for viewing for my posts. |
June 19, 2022, 14:47 |
The lack of response might be related to the complexity of the problem that you raise.
In your post you discuss both block-coupled solvers and multi-region problems. Both these issues have recently attracted a lot of attention in this conmunity recently. For multi-region problems, e.g., implicit handling of coupled patches have been proposed in https://www.openfoam.com/news/main-n...mplicit-cyclic. Block-coupled solvers have discussed in e.g. the recent OpenFoam workshops. A good overview of both topics might be required to make a next step. I am happy to share my limited insight. |
June 23, 2022, 16:28 |
Rep Power: 7 |
Sorry but I fail to see why a simple mathematical problem should be so difficult to implement. But it does not matter since I am closing the thread as I was using the wrong terminology all along:
Implicit solution techniques for coupled multi-field problems – Block Solution, Coupled Matrices Advanced Training at the OpenFOAM Workshop Jun 6 2010 discusses two topics concerning implicit coupling namely Domain (Matrix) and Equation (Block) coupling What I am interested in is domain coupling ( so one variable in my case over more than two adjacent meshes) The hack for this was inserted into conjugate heat transfer solver long time ago - see p 10 in the above pdf where you will find a function hook part of the coupledFvScalarMatrix class This function was later renamed set as I checked by downloading the source code for foam-extend-1.6 and that code was later improved and expanded upon in later foam-extend versions. So unless I am wrong, I have a feeling one can add the boundary conditions k1*grad T1 = k2*grad T2 (adjacent meshes with different heat conductivities) to the overall matrix equations which would mean that I could have solved this problem more than 3 years ago with existing OF code instead of wasting my time Such is life |
Problem with chtMultiregionFoam radiation boundary condition | baran_foam | OpenFOAM Running, Solving & CFD | 10 | December 17, 2019 17:36 |
Problem simulating the temperature rise in a composite material (chtMultiRegionFoam) | Adam_K | OpenFOAM Running, Solving & CFD | 2 | March 27, 2019 06:51 |
Isosurface, volume integrals, etc... Inside a Block instead of the whole Region | JohnAB | STAR-CCM+ | 0 | November 13, 2014 17:52 |
What is weakstrong coupling in FSI problems | hajo | OpenFOAM Running, Solving & CFD | 5 | May 15, 2008 01:45 |
problems with viewing mesh block by block | James | CFX | 0 | January 22, 2008 12:11 |
