OpenQBMM error when initialized moments are set to zero |
May 7, 2021, 04:41 |
K
Rep Power: 8 |
Hey Foamers
I am working with the OpenQBMM v 5.0.1 (https://www.openqbmm.org/) developed by Prof. Passalacqua and his group using the pbeTransportFoam solver. My first thought was to simulate zero particles which means that the associated moments will all be equal to zero. Since we are solving the population balance equations using moments in a steady velocity field (in pbeTransportFoam solver) implies that all the moments should remain zero. But unfortunately, when I run the solver with zero initialzed value of moments it crashes giving me an error saying Foam::sigFpe::sigHandler(int) at ??:? When I run the solver with a non-zero value of initialized moments it give me results. So I am suspecting it due to division by zero. Has someone come across this error ? or even better fixed it ? |
Possible bug with stitchMesh and cyclics in OpenFoam | Jack001 | OpenFOAM Pre-Processing | 0 | May 21, 2016 08:00 |
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
Installing OpenFOAM 1.6-ext on Ubuntu 11.10 | immortality | OpenFOAM Installation | 17 | May 6, 2013 17:43 |
Help with GNUPlot | Renato. | Main CFD Forum | 6 | June 6, 2007 19:51 |
Problems with installation | jonititan | OpenFOAM Installation | 4 | November 6, 2005 04:16 |
