Normal components (inside & outside) of a vector field found at the interface
Old   May 16, 2021, 09:38
Default Normal components (inside & outside) of a vector field found at the interface
X
mcfdma is on a distinguished road
Hi.
I'm working on a two-phase flow simulation and have modified the interFoam solver to include the electrostatics component to get an electrohydrodynamic solver (similar to http://openfoamwiki.net/index.php/Co...ectromagnetics)
I'm calculating the electric field using the gradient of electric potential given by the equation \bold E = -\nabla \phi, which in my header file looks like:
E = -fvc::grad(Ue);
For my simulation, I'm interested in finding the normal component of E inside and outside the interface.
I've tried Paraview, where I applied contour to get the isosurface followed by normal glyphs. This gave me the normal component of E outside of the interface, and I was unable to get the normal component of E inside. Also, this isn't a quick process, and I want to know how I can createFields for both the normal components in my solver.
What I plan to understand is the following:
1. How to acquire(&code) the surface normal vector. This is what I've done (can be wrong, and if it is, do let me know).
	surfaceVectorField phiNormal
	(   mesh.Sf()/mesh.magSf()//(fvc::reconstruct(phi))/mag(fvc::reconstruct(phi))
2. How to use this surface normal vector to find the 2 normal components.
I appreciate your time and would be grateful if I can get some assistance on this area.
mcfdma is offline   Reply With Quote
Old   May 18, 2021, 17:15
X
I have attached an image to explain my question better. Normal inside and outside of the surface.
ehd, electrohydrodynamic, interface, normal to surface
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[Gmsh] Insatlling gmsh from the source code-issue? CFD-Lover OpenFOAM Meshing & Mesh Conversion 20 June 12, 2018 06:39
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 17:38
Radiation interface hinca CFX 15 January 26, 2014 17:11
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
