Change solver tolerance depending on solution
Old   May 30, 2021, 23:34
Default Change solver tolerance depending on solution
Martin
msaravia is on a distinguished road
Hello everyone.
I need to change the solver tolerances while running. More specifically, I need to change the absolute tolerance of the solver after a certain number of iterations.
I know the fvMatrix class has a solver object; but neither of them has a getter implemented to return a reference to the tolerance parameter (which is read from fvSolution).
Do you have any idea about how I can achieve this? Thanks in advance.
msaravia is offline   Reply With Quote
Old   May 31, 2021, 01:51
Siassei is on a distinguished road
A little hint.
Not tested until yet, but adding runTimeModifiable to fvSolution?
doc:
runTimeModifiable
Switch for whether dictionaries, e.g. controlDict, are re-read during a simulation at the beginning of each time step, allowing the user to modify parameters during a simulation.
Siassei is offline   Reply With Quote
Old   May 31, 2021, 10:08
Martin
Originally Posted by Siassei View Post
A little hint.
doc:
runTimeModifiable
Hi Thomas, thank for the hint! I have considered it, specially because if I get to access the fvSolution object I would need to make sure that this option is activated in order to get the dictionary to be read at every iteation.
Apparently I can access the linear solver controls through the mesh as mesh.solverDict(fieldName). fvMesh is derived from fvSolution so that all fields have access to the fvSolution from the mesh reference they hold.
I will keep you posted
Old   June 1, 2021, 11:55
Martin
Well, after trying several things. I managed to change the solver settings at runtime without needing to write the dictionary to file.
For anyone needing to do it, here it is my solution.
a) Create a dictionary reading the original solver settings.
IOdictionary solDict
	IOobject
	"fvSolution",
	runTime.caseSystem(),
	runTime,
	IOobject::MUST_READ,
	IOobject::AUTO_WRITE
dictionary& solverControl = solDict.subDict("solvers").subDict("A");
b) modify the solver control as needed
solverControl.set("tolerance", 1E-10);
C) Now, the magic. Just call the solver with the control dictionary as argument.
AEqn.solve(solverControl);
The solution was so simple that now I feel the dumbest person in the world. You can make fun of me; I take it.
However, I still need to change the number of non-orthogonal correctors on the fly, which apparently has not a simple solution.
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
icoFoam Courant number growth problem tdof OpenFOAM Running, Solving & CFD 12 May 24, 2023 14:00
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
alpha value negative silviliril OpenFOAM Programming & Development 1 June 1, 2018 14:57
2D isothermal cylinder not converging UPengineer OpenFOAM Running, Solving & CFD 7 March 13, 2014 05:17
