A data format error about fvc::div(surfaceScalarField,volVectorField) |
Rep Power: 5 ![]() |
Hi foamers,
I use the OpenFOAM 4.0. I want to caculate the divergence of heat flux multiply temperature gradient. So I definite the gradient of T and heat flux imitating velocity U and phi in my createfield.H by volVectorField gradT(fvc::grad(T)); surfaceScalarField phigradT(linearInterpolate(k*gradT) & Mesh.Sf()); And the solve equation is fvScalarMatrix SEqn ( fvm::ddt(rhoFuel, S) + fvm::div(phiFuel, S) + fvc::div(phigradT, gradT) ) S is entropy and volScalarField. But when I compile my code, the message is error: no match for ‘operator-’ (operand types are ‘Foam::tmp<Foam::fvMatrix<double> >’ and ‘Foam::tmp<Foam::GeometricField<Foam::Vector<doubl e>, Foam::fvPatchField, Foam::volMesh> >’) - fvc::div(phigradT, gradT) ^ In file included from /opt/openfoam4/src/OpenFOAM/lnInclude/zero.H:101:0, from /opt/openfoam4/src/OpenFOAM/lnInclude/UList.H:49, from /opt/openfoam4/src/OpenFOAM/lnInclude/List.H:43, from /opt/openfoam4/src/OpenFOAM/lnInclude/labelList.H:48, from /opt/openfoam4/src/OpenFOAM/lnInclude/UPstream.H:42, from /opt/openfoam4/src/OpenFOAM/lnInclude/Pstream.H:42, from /opt/openfoam4/src/OpenFOAM/lnInclude/parRun.H:35, from /opt/openfoam4/src/finiteVolume/lnInclude/fvCFD.H:4, I don’t know how to set the gradient and the format of the surface flux is correct. |
Yogesh Bapat
Rep Power: 15 ![]() |
You can check diffusion term implementation is some other solver.
-Yogesh |
Automatic Data Export (ascii format) | A Kourm | FLUENT | 4 | March 7, 2021 14:08 |
[General] Paraview data format conversion from vtk to parallel prog data format. | odho | ParaView | 0 | September 20, 2016 07:01 |
Write data from probe locations in binary format | kozden | OpenFOAM Post-Processing | 0 | June 18, 2016 05:25 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
Smallest binary file format to save large data | Zonexo | Main CFD Forum | 2 | June 2, 2008 20:25 |
