September 22, 2021, 22:23 |
General Question about code developing
mohammad
Rep Power: 11 |
Hi everyone,
I have a general question about OF coding. Considering that I have started a simulation using OF. Then during running this case, I have changed the OF library and compiled it. So does it affect the running case with the previously compiled configuration? Cheers, Mohammad |
September 24, 2021, 10:11 |
mohammad
Rep Power: 11 |
Nobody interested in answering my question?
September 24, 2021, 12:20 |
#3 | |
Rodrigo
Being more pragmatic: In principle it shall not affect your already-running case. Of course, if you stop&resume it the system will make use of the new binaries. |
September 25, 2021, 03:40 |
#4 | |
mohammad
Rep Power: 11 |
You was so specific indeed. I mean the already-running case. So in your opinion, making a change in library and compiling it doesn't affect that case. |
September 26, 2021, 02:06 |
#5 | |
Francesco Del Citto
Rep Power: 18 |
As guin wrote, it depends. I had systems in which changing a binary used by a simulation was causing the simulation stopping with a "BUS error", while on other systems it did not stop. However, it's never a good idea... |
September 26, 2021, 19:24 |
mohammad
Rep Power: 11 |
September 30, 2021, 06:39 |
Ali Baratian
Rep Power: 12 |
hello everybody
i wonder whether it is possible to run OF codes on a generic compiler (not through the TERMINAL determined by the official releases)? for example can i run the Cavity tutorial codes on CodeBlocks C++ compiler? i think if OF is a real open source code it must be possible! thanks in advance. |
September 30, 2021, 14:45 |
#8 | |
Francesco Del Citto
Rep Power: 18 |
October 30, 2021, 12:07 |
Ali Baratian
Rep Power: 12 |
You mean it is possible for example to copy paste OF codes in a generic c++ compiler and run?
If that is! I am really wondered by that. |
October 31, 2021, 08:13 |
#10 | |
Francesco Del Citto
Rep Power: 18 |
No, I am not saying that. To be honest, I'm not sure I understood what you mean with that. What I am saying is that you can use different compilers to recompile the whole OpenFOAM package, including your custom libraries and applications. OpenFOAM is C++ code, although with a unique code style, but you cannot take just a solver source, it includes headers and imports lots of libraries from the openfoam source directories that must be recompiled as well. |
A general question on using UDF for defining reaction kinetics | Morijef | Fluent UDF and Scheme Programming | 0 | September 19, 2018 15:37 |
question about complete code of airfoil | batuning | Main CFD Forum | 0 | October 26, 2017 03:24 |
General question regarding convergence | raviramesh10 | CFD Freelancers | 0 | June 20, 2017 07:09 |
Debugging technics - CFD code developing | leo_NM | Main CFD Forum | 2 | June 9, 2016 11:22 |
general question | Madhukar Rapaka | FLUENT | 1 | June 28, 2006 08:03 |
