EpsilonWallFunction crashes with two connected walls |
Rep Power: 6 ![]() |
Dear all,
I am implementing an own EpsilonWallFunction for a k-epsilon simulation. Inside the WF I would like to compute both the strain rate and vorticity invariants. Here is the structure of the code : Code:
void Foam::MyepsilonWallFunctionFvPatchScalarField::calculate ( const turbulenceModel& turbModel, const List<scalar>& cornerWeights, const fvPatch& patch, scalarField& G0, scalarField& epsilon0 ) { const volVectorField& Ut = turbModel.U(); /* Strain rate invariant */ volSymmTensorField S = symm(fvc::grad(Ut)); /* Vorticity invariant */ volTensorField W = skew(fvc::grad(Ut)); ... } The errors are: Code:
Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.000410734772, No Iterations 5 smoothSolver: Solving for Uy, Initial residual = 0.999853259, Final residual = 0.000909577149, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.999796967, Final residual = 0.000793379745, No Iterations 4 GAMG: Solving for p, Initial residual = 1, Final residual = 0.000988755628, No Iterations 23 time step continuity errors : sum local = 4.17199017e-05, global = 1.25994915e-05, cumulative = 1.25994915e-05 [c06c4f9bf5aa:13379] 1 more process has sent help message help-mpi-errors.txt / mpi_errors_are_fatal [c06c4f9bf5aa:13379] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages [c06c4f9bf5aa:13385] *** An error occurred in MPI_Waitall [c06c4f9bf5aa:13385] *** reported by process [1137901569,0] [c06c4f9bf5aa:13385] *** on communicator MPI COMMUNICATOR 3 SPLIT FROM 0 [c06c4f9bf5aa:13385] *** MPI_ERR_TRUNCATE: message truncated [c06c4f9bf5aa:13385] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort, [c06c4f9bf5aa:13385] *** and potentially your MPI job) • After some tests, the error occurs at the gradient computation line; • It runs in serial; • It runs for 5 processors but not for 15; I would truly appreciate any help or comments! thanks in advance! |
openfoam 7, wall function |
[ICEM] Defining Interfaces and Splitting Internal Walls ICEM-FLUENT | pmtgt | ANSYS Meshing & Geometry | 8 | June 4, 2021 07:15 |
[snappyHexMesh] Reading checkMesh output | streamline90 | OpenFOAM Meshing & Mesh Conversion | 4 | October 28, 2019 09:52 |
twoPhaseEulerFoam bubble column crashes due to problems at outlet region | hester | OpenFOAM Running, Solving & CFD | 4 | May 18, 2016 10:20 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
