Assigning a component of a volTensorField a particular value
Old   November 23, 2021, 15:27
Default Assigning a component of a volTensorField a particular value
Anonymous
backscatter is on a distinguished road
Is there any elegant way to manually assign one component of a volTensorField a particular value? Let's say we have to replace the (1,1) component of the tensor field by zero, how would you elegantly get this done?
backscatter is offline   Reply With Quote
Old   November 24, 2021, 09:13
Michael Alletto
mAlletto will become famous soon enough
https://www.openfoam.com/documentati...1_1Tensor.html
you can assess the (1,1) via the xx() function.
mAlletto is offline   Reply With Quote
Old   November 24, 2021, 13:14
s1291's Avatar
s1291 is on a distinguished road
Originally Posted by backscatter View Post
if T is tensor, you can access its components via:
T.xx();
T.xy();
T.xz();
// etc.
You can also assign values to the components, e.g:
T.xx() = 5.0;
T.xy() = -99.0;
//etc
"When in doubt, use brute force." -- Ken Thompson
s1291 is offline   Reply With Quote
OpenFOAM extended 4.0 Error with Multinode Set-up Liweix OpenFOAM Running, Solving & CFD 1 February 18, 2020 00:50
Error running openfoam in parallel fede32 OpenFOAM Programming & Development 5 October 4, 2018 16:38
Access (I, J) component of a volTensorField longonig OpenFOAM Programming & Development 2 February 15, 2018 07:53
Momentum source coefficient, cylindrical coordinates, circumferential component? polakse CFX 15 January 18, 2016 02:40
probes for a component of a volTensorField titio OpenFOAM Post-Processing 0 July 2, 2010 13:50
