November 22, 2013, 05:59 |
looking for solver for plasma arc simulation
Robert Castilla
Rep Power: 17 |
there is some documentation about implementing plasma arc welding simulation with OpenFoam, specially by Sass-Tisovskaya or by H. Nilsson. Although the implementation of the solver is completely described in some paper, I wonder if it is possible to get it. It doesn't seems to be available in standar OF distribution and I couldn't also find it in the OF-extend project. Anyone knows if it is possible to get it? Thank you Robert |
November 22, 2013, 07:22 |
Anton Kidess
Rep Power: 30 |
Hey Robert, your best chance is to write directly to the authors of those works. Also check out the work by Alireza Javidi. Sass-Tisovskaya also released some code, but I don't think it's what you are looking for: http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2012/
- Anton
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
November 22, 2013, 08:30 |
Robert Castilla
Rep Power: 17 |
Hi, Anton,
thank you very much for your quick reply. Yes, you are right, the best option is to contact directly the developers, but I wanted first to find an officlally released solver. The one that you mention in the OS CFD course is not what I am looking for, as you said. So, I will try to contact the developers. Best regards Robert P.S. BTW, I think that the Alireza Javidi link is wrong, but don't worry, I have been googling and I have found the information. Thank you, again. |
December 17, 2021, 05:25 |
numerical simulation of Plasma arc cutting with openfoam
TAKILT Hocine
Hello Robert!
Have you found a method to implement your simulations? I am interested to know what is your method (script... ). Thanks for your answer. Hocine |
plasma modeling |
UDF code for arc as heat flux in simulation | Alireza Kohandehghan | Fluent UDF and Scheme Programming | 5 | April 18, 2019 10:18 |
[blockMesh] defining and connecting two circular pipes using blockMesh | Hale | OpenFOAM Meshing & Mesh Conversion | 4 | July 31, 2013 07:10 |
icoFoam- unphysical results | Mirage12 | OpenFOAM Running, Solving & CFD | 2 | July 12, 2013 03:52 |
[blockMesh] Mesh generation for a pipe with bendbends using blockMesh | jaswi | OpenFOAM Meshing & Mesh Conversion | 14 | February 28, 2013 22:06 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
