December 28, 2021, 03:43 |
Add an equation to CompressibleInterFoam
Antonio
Rep Power: 4 |
I am trying to implement "waveTrasmessive.BC" in compressibleInterFoam. I added this code to createFilds.h
volScalarField DrhoDp ( IOobject ( "DrhoDp", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), alpha1*psi1 + alpha2*psi2 ); Code:
DrhoDp = psi1*alpha1 + psi2*alpha2; Does anyone know by which this error depend on? How can I fix it? Thanks! |
December 29, 2021, 17:13 |
Lorenzo
Rep Power: 6 |
The errors say that all the variables (alpha1 alpha2 psi1 psi2) were not declared before. Try to look if they are defined after DrhoDp.. If so, move the declaration of DrhoDp after them. Regards, Lorenzo |
December 30, 2021, 06:30 |
thanks Lorenzo
#3 | |
Antonio
Rep Power: 4 |
Hi Lorenzo, thank you for your response. As suggested in a previous topic, I added the first equation in createfields.h , I got this: Code:
Info<< "Reading field p_rgh\n" << endl; volScalarField p_rgh ( IOobject ( "p_rgh", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); Info<< "Reading field U\n" << endl; volVectorField U ( IOobject ( "U", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); #include "createPhi.H" Info<< "Constructing twoPhaseMixtureThermo\n" << endl; twoPhaseMixtureThermo mixture(mesh); volScalarField& alpha1(mixture.alpha1()); volScalarField& alpha2(mixture.alpha2()); Info<< "Reading thermophysical properties\n" << endl; volScalarField& rho1 = mixture.thermo1().rho(); volScalarField& rho2 = mixture.thermo2().rho(); volScalarField rho ( IOobject ( "rho", runTime.timeName(), mesh, IOobject::READ_IF_PRESENT, IOobject::AUTO_WRITE ), alpha1*rho1 + alpha2*rho2 ); dimensionedScalar pMin ( "pMin", dimPressure, mixture ); mesh.setFluxRequired(p_rgh.name()); #include "readGravitationalAcceleration.H" #include "readhRef.H" #include "gh.H" // Mass flux // Initialisation does not matter because rhoPhi is reset after the // alpha1 solution before it is used in the U equation. surfaceScalarField rhoPhi ( IOobject ( "rhoPhi", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), fvc::interpolate(rho)*phi ); volScalarField dgdt ( pos(alpha2)*fvc::div(phi)/max(alpha2, scalar(0.0001)) ); // Construct interface from alpha1 distribution interfaceProperties interface(alpha1, U, mixture); volScalarField DrhoDp ( IOobject ( "DrhoDp", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), alpha1*psi1 + alpha2*psi2 ); // Construct compressible turbulence model autoPtr<compressible::turbulenceModel> turbulence ( compressible::turbulenceModel::New(rho, U, rhoPhi, mixture) ); Info<< "Creating field kinetic energy K\n" << endl; volScalarField K("K", 0.5*magSqr(U)); Code:
{ word alphaScheme("div(phi,alpha)"); word alpharScheme("div(phirb,alpha)"); surfaceScalarField phir(phic*interface.nHatf()); for (int gCorr=0; gCorr<nAlphaCorr; gCorr++) { volScalarField::Internal Sp ( IOobject ( "Sp", runTime.timeName(), mesh ), mesh, dimensionedScalar("Sp", dgdt.dimensions(), 0.0) ); volScalarField::Internal Su ( IOobject ( "Su", runTime.timeName(), mesh ), // Divergence term is handled explicitly to be // consistent with the explicit transport solution divU*min(alpha1, scalar(1)) ); forAll(dgdt, celli) { if (dgdt[celli] > 0.0 && alpha1[celli] > 0.0) { Sp[celli] -= dgdt[celli]*alpha1[celli]; Su[celli] += dgdt[celli]*alpha1[celli]; } else if (dgdt[celli] < 0.0 && alpha1[celli] < 1.0) { Sp[celli] += dgdt[celli]*(1.0 - alpha1[celli]); } } surfaceScalarField alphaPhi1 ( fvc::flux ( phi, alpha1, alphaScheme ) + fvc::flux ( -fvc::flux(-phir, alpha2, alpharScheme), alpha1, alpharScheme ) ); MULES::explicitSolve ( geometricOneField(), alpha1, phi, alphaPhi1, Sp, Su, 1, 0 ); surfaceScalarField rho1f(fvc::interpolate(rho1)); surfaceScalarField rho2f(fvc::interpolate(rho2)); rhoPhi = alphaPhi1*(rho1f - rho2f) + phi*rho2f; alpha2 = scalar(1) - alpha1; DrhoDp = psi1*alpha1 + psi2*alpha2; } Info<< "Liquid phase volume fraction = " << alpha1.weightedAverage(mesh.V()).value() << " Min(" << alpha1.name() << ") = " << min(alpha1).value() << " Min(" << alpha2.name() << ") = " << min(alpha2).value() << endl; } May you give me some advice? I am still a beginner , and I'm sure many users might find this useful! thank you |
vof wavetrasmessive fluid |
Add soure terms to the momentum equation | Shibi | OpenFOAM Programming & Development | 1 | June 23, 2022 15:27 |
How to manually add Boussinesq Approximation to the momentum equation of a solver? | chymalaia | OpenFOAM Programming & Development | 2 | February 5, 2021 09:07 |
How can I add or modify an equation?? | Jung hoo | OpenFOAM Programming & Development | 4 | July 10, 2016 08:23 |
add temperature equation to interFoam | nygbook | OpenFOAM Running, Solving & CFD | 3 | September 4, 2011 07:28 |
UDF to add two governing equation?? | T.K. Yang | FLUENT | 0 | May 9, 2006 02:54 |
