February 6, 2022, 10:42 |
Help with read in values from a file
TWB
Rep Power: 19 |
I have a txt file with data: Orientation (1 7.87011e-08 0 -7.87011e-08 1 0 0 0 1) Orientation (1 9.07449e-08 0 -9.07449e-08 1 0 0 0 1) I have a modified mesh deformation codee coming from oscillatingRotatingMotion. In that code, I need to read in the 2 tensor values. Actually, I just need the values, whether read in as tensor or not is not important. I tried: orientationdict_ ( IOobject ( "orientationdict", runTime_.constant(), mesh_, IOobject::MUST_READ, IOobject::NO_WRITE ) ), tensor orientation = orientationdict.lookup("orientation"); but it doesn't compile. I got the error: Code:
prototype_retract_motionPointPatchVectorField.C:224:3: error: ‘runTime_’ was not declared in this scope 224 | runTime_.constant(), | ^~~~~~~~ prototype_retract_motionPointPatchVectorField.C:225:3: error: ‘mesh_’ was not declared in this scope; did you mean ‘mesh’? 225 | mesh_, | ^~~~~ | mesh prototype_retract_motionPointPatchVectorField.C:219:3: error: ‘orientationdict_’ was not declared in this scope 219 | orientationdict_ | ^~~~~~~~~~~~~~~~ prototype_retract_motionPointPatchVectorField.C:231:10: error: expected primary-expression before ‘orientation’ 231 | tensor orientation = orientationdict.lookup("orientation"); Hope someoe can help to correct me. Thanks. |
February 7, 2022, 10:09 |
TWB
Rep Power: 19 |
I was thinking in terms of how OF uses dictionary.
But then I realised that it's just a piece of C++ code and I can do it the c++ way too. So to ans my own qn: My file, consisting of actually 2 tensors 1 3.02823e-07 0 -3.02823e-07 1 0 0 0 1 1 3.26108e-07 0 -3.26108e-07 1 0 0 0 1 and I just need to extract the 2nd value of each tensor. add Code:
#include <iostream> #include <fstream> using namespace std; and this part to the file reading: Code:
// Read from the text file ifstream file; file.open("orientation2.dat"); string line; int i = 0; double tmp_orientation, orient[2]; while(file.good() && (getline(file, line))) { istringstream iss(line); iss >> tmp_orientation >> orient[i] >> tmp_orientation >> tmp_orientation >> tmp_orientation >> tmp_orientation >> tmp_orientation >> tmp_orientation >> tmp_orientation; //cout << orient[i]; } file.close(); scalar orient_pitch_old = asin(orient[0]); scalar orient_pitch = asin(orient[1]); |
[Other] Tabulated thermophysicalProperties library | chriss85 | OpenFOAM Community Contributions | 62 | October 2, 2022 03:50 |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 35 | April 29, 2022 15:35 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
