rhoSimpleFoam error while run with turbulence
Old   February 28, 2022, 11:03
Default rhoSimpleFoam error while run with turbulence
Nguyen Trong Hiep
hiep.nguyentrong is on a distinguished road
When i try to run rhoSimpleFoam or steadyCompressibleFoam (foam-extend-4.1) with turbulence models (kEpsilon or kOmegaSST), i get this error.
My case is transonic flow over NACA0012. It run fine with laminar or other version like OpenFOAM-v2112 or OpenFOAM-dev.
How can i solve this? Is it a bug?
Selecting RAS turbulence model kEpsilon
Program received signal SIGFPE, Arithmetic exception.
0x00007ffff721d84f in Foam::compressible::RASModels::mutkWallFunctionFvPatchScalarField::calcMut (this=0x555555dd1760) at derivedFvPatchFields/wallFunctions/mutWallFunctions/mutkWallFunction/mutkWallFunctionFvPatchScalarField.C:69
69	            Cmu25*y[faceI]*sqrt(k[faceCellI])/(muw[faceI]/rhow[faceI]);
hiep.nguyentrong is offline   Reply With Quote
Old   March 3, 2022, 04:47
Michael Alletto
mAlletto will become famous soon enough
Seems like a division by zero -> rhok is probably zero some where
mAlletto is offline   Reply With Quote
Old   March 7, 2022, 03:24
Nguyen Trong Hiep
Thank you for reply.
I tried to initiate all turbulence variable with difference value but still get floating point at start
Old   March 7, 2022, 04:27
Michael Alletto
Usually one adds a small value to the denominator to avoid divisions by zero
Old   March 8, 2022, 03:05
Nguyen Trong Hiep
i tried add 0.1 value at wall and internalField, but still get the error. I did same with other field and nothing change
    "(WALL3|WALL4)"
        type            mutkWallFunction;
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0.1;
Old   March 8, 2022, 03:46
Michael Alletto
The small value like 1.0e-04 should go in the denominator in the source code
Old   March 8, 2022, 03:59
Nguyen Trong Hiep
Thank you but i did not solve the problem. Here is my 0 file:
alphat:
dimensions      [1 -1 -1 0 0 0 0];
internalField   uniform 1e-4;
boundaryField
    "(INLE1|PRES2)"
        type            calculated;
        value           uniform 1e-4;
    "(WALL3|WALL4)"
        type            alphatWallFunction;
        value           uniform 1e-4;
k:
boundaryField
    "(INLE1|PRES2)"
        type            inletOutlet;
        inletValue      uniform $kInlet;
        value           uniform $kInlet;
    "(WALL3|WALL4)"
        type            kqRWallFunction;
    //#includeEtc "caseDicts/setConstraintTypes"
mut:
boundaryField
    "(WALL3|WALL4)"
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 1e-4;
    "(INLE1|PRES2)"
        type            calculated;
        value           uniform 1e-4;
    frontAndBackPlanes
        type            empty;
omega
//omegaInlet      10;
omegaInlet 		4000;
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform $omegaInlet;
boundaryField
    "(INLE1|PRES2)"
        type            inletOutlet;
        inletValue      uniform $omegaInlet;
        value           uniform $omegaInlet;
    "(WALL3|WALL4)"
        type            omegaWallFunction;
Old   March 8, 2022, 04:23
Michael Alletto
The keyword value is just a placeholder since the boundary conditions are derived from a fixedValue b.c. you have to modify the source code to avoid a floating point exception
Only two turbulence options available in CFX Pre Jack001 CFX 5 March 30, 2016 02:47
Strange Behavior of A Mesh Run at Two Dfferent Velocities Using Turbulence Model zachnap Main CFD Forum 0 May 11, 2011 15:22
How can run MRFSimpleFoam with KOmegaSST turbulence model waynezw0618 OpenFOAM Running, Solving & CFD 0 April 21, 2008 04:40
RhoSimpleFoam negative pressure gzink OpenFOAM Running, Solving & CFD 10 June 4, 2007 05:35
Turbulence boundary values lego Main CFD Forum 0 October 24, 2002 13:47
