February 19, 2010, 03:54 |
properties of the interfaceProperties class
Roman Thiele
Rep Power: 20 |
Hej;
I have questions about the interfaceProperties class. What does Code:
nHatf_ Also: in the function calculateK() in the first two lines Code:
00101 const fvMesh& mesh = alpha1_.mesh(); 00102 const surfaceVectorField& Sf = mesh.Sf(); Code:
surfaceScalarField& alphaAreas = mesh.magSf() ; If this does not work, is it possible to get the interface area between the two phases somehow else? Thanks in advance!
~roman |
interfoam, multiphase, two-phase |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Properties of air versus temperature AND pressure | Vincent | Main CFD Forum | 5 | July 28, 2008 06:28 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
About UList and List class | leosding | OpenFOAM Running, Solving & CFD | 1 | December 1, 2005 23:52 |
