The issue of time step on simulation of viscoelastic fluid's upstream flow at high Wi |
March 31, 2022, 23:34 |
SUN
Rep Power: 4 |
Dear all, I am now adopting rheoTool(A open tool at framework of openfoam) to simulate the viscoelastic fluid's upstream flow at high Wi. The algorithm is implanted based on this manuscript:https://arxiv.org/ftp/arxiv/papers/2203/2203.09239.pdf
When the case's time step is set to 0.001s, some upstream flow is observed. However, the case would be collapsed as continue to run it. Then the starting time step is set to 0.0001s. The case would be run all the time. However, the case always presents steady feature where the upstream flow would not be observed. The case and solver is uploaded. All suggeations are welcomed. Thanks a lot. |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores | puneet336 | OpenFOAM Running, Solving & CFD | 11 | April 7, 2019 00:58 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
