The issue of time step on simulation of viscoelastic fluid's upstream flow at high Wi
Old   March 31, 2022, 23:34
Default The issue of time step on simulation of viscoelastic fluid's upstream flow at high Wi
SUN
mufeng is on a distinguished road
Dear all, I am now adopting rheoTool(A open tool at framework of openfoam) to simulate the viscoelastic fluid's upstream flow at high Wi. The algorithm is implanted based on this manuscript:https://arxiv.org/ftp/arxiv/papers/2203/2203.09239.pdf
When the case's time step is set to 0.001s, some upstream flow is observed. However, the case would be collapsed as continue to run it. Then the starting time step is set to 0.0001s. The case would be run all the time. However, the case always presents steady feature where the upstream flow would not be observed.
The case and solver is uploaded. All suggeations are welcomed. Thanks a lot.
mufeng is offline   Reply With Quote
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 09:10
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores puneet336 OpenFOAM Running, Solving & CFD 11 April 7, 2019 00:58
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
