Different results with custom 6dof solver in pitch with newmark scheme |
April 23, 2022, 21:31 |
TWB
Rep Power: 19 |
I am trying to write my own custom 6dof (only in pitch) solver under the solidBodyMotionFunction class, using the newmark scheme. Reason is that my body undergoes large pitching rotation and if I use the org sixDoFRigidBodyMotion, the mesh deformation will be severe. However, if I run it under the solidBodyMotionFunction class, the whole body will pitch as a whole with no deformation. I start off with modifing the rotatingmotion code since that's the nearest to what I want. So instead of prescribed rotation, the angle will be determined by the 6dof solver. I followed the newmark scheme as given in the newmmark.C under the sixDoFRigidBodyMotion: Code:
//newmark scheme angular_acc_z = accelerationRelaxation_*(moment_z/momentOfInertia_[2]); angular_vel_z = angular_vel_z_old + accelerationDamping_*delta_time*(gamma_*angular_acc_z + (1. - gamma_)*angular_acc_z_old); //angle = angle_old + angular_vel_z_old*delta_time + accelerationDamping_*delta_time*delta_time*(beta_*angular_acc_z + (0.5 - beta_)*angular_acc_z_old); angle = angular_vel_z_old*delta_time + accelerationDamping_*delta_time*delta_time*(beta_*angular_acc_z + (0.5 - beta_)*angular_acc_z_old); I then compared my case with the wingMotion2D from the tutorial. I modified a bit to make it just simple pitch rotation in 1dof . The results I obtained are similar for t = 0.1 and 0.2 but then the results start to diverge and for my case, the pitch angle keeps increasing. However, for the org tutorial, the pitch angle starts to reverse after ~ t = 0.4. I wonder why. Is there anything which I missed out? Is using a custom 6dof solver under the solidBodyMotionFunction class sufficient to get the correct ans? Hope someone can help or give some suggestions. Thanks. |
May 1, 2022, 21:08 |
TWB
Rep Power: 19 |
Anyone can help?
I'm still struggling with the error. After t ~ 0.2s, the difference between my result and OF's gets bigger and bigger. My understanding of 6dof, simplified for my problem is as follows: For simple pitch only 1dof z axis mz = external pitch force izz = moment of inertia in z axis center of rotation = center of mass angular acceleration acc = mz/izz v = u + acc*t, where v, u and t = new velocity, old velocity, delta time new final displacement theta = theta_old + u*t + 0.5*acc*t^2 That's the simplest way. However, for better accuracy and stability, we can use the newmark scheme whereby: acc = accelerationRelaxation_*(mz/izz); v = u + accelerationDamping_*t*(gamma_*acc + (1. - gamma_)*acc_old); theta = theta_old + u*t + accelerationDamping_*t^2*(beta_*acc + (0.5 - beta_)*acc_old); Is there anything wrong with the above formulas? |
Duplicate library entries when running a solver with custom library | francescomarra | OpenFOAM Programming & Development | 3 | May 17, 2022 08:37 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
The different among the Pitch options | MNMK | CFX | 2 | November 12, 2020 03:27 |
Error Interpolating Results onto New Mesh | nammeh | CFX | 1 | March 26, 2019 12:08 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
