How to add forces from another continuous phase in KinematicCloud?
Old   May 10, 2022, 21:53
Default How to add forces from another continuous phase in KinematicCloud?
Huan Zhang
Jasper Z is on a distinguished road
Dear all,
I want to simulate three-phase flows with two phases using Euler method and another phase using lagrangian. However, the problem is that, the forces exerted on lagrangian particles should come from both two continuous phases. I have looked at the kinematicCloudI.H and kinematicParcel.C, and found that only one continuous properties (e.g., uc, muc) were used to calculate the forces on a particle. If I want to add forces from another continuous phase, do I have to modify the codes in these two files? Please give me a hint.
Regards,
Jasper
Jasper Z is offline   Reply With Quote
How to enable two way-coupling between discrete and continuous phase? alvinthum ANSYS 4 April 15, 2018 21:45
Simulating discrete solid phase inside a continuous fluid phase hosseinamir71 CONVERGE 1 August 31, 2017 16:02
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
Three Phase flow into a reservoir... akjha Main CFD Forum 0 December 15, 2014 07:01
add user scalar in one phase zhu CFX 0 April 27, 2002 03:45
