Viscous heating in chtMultiRegionFoam
Old   March 21, 2016, 12:12
Default Viscous heating in chtMultiRegionFoam
Pekka Pasanen
zordiack is on a distinguished road
Hi, I just made initial implementation of viscous heating into chtMultiRegionFoam. This is the modified EEqn:
    volScalarField& he = thermo.he();
    volTensorField gradU = fvc::grad(U);
    // tau = 2*mu*D, D = deformation rate tensor
    volTensorField tau = turb.muEff() * (gradU + gradU.T());
    fvScalarMatrix EEqn
        fvm::ddt(rho, he) + fvm::div(phi, he)
      + fvc::ddt(rho, K) + fvc::div(phi, K)
            he.name() == "e"
          ? fvc::div
                fvc::absolute(phi/fvc::interpolate(rho), U),
                p,
                "div(phiv,p)"
          : -dpdt
      - fvm::laplacian(turb.alphaEff(), he)
        rho*(U&g)
      + fvc::div(tau & U) // viscous heating
      + rad.Sh(thermo)
      + fvOptions(rho, he)
Is this the correct way to do it? If not, how could it be improved? For sources I used http://cfd.direct/openfoam/energy-equation/ and the excellent pdf made by Tobias Holtzmann, which you can find here http://www.holzmann-cfd.de/index.php...s-and-openfoam.
I basically tried to implement the other missing mechanical source, which is div(tau & U), and tau = turb.muEff() * (gradU + gradU.T()).
I'm wishing for comments and feedback, you can get the code from here:
https://github.com/zordiack/foam-dev
zordiack is offline   Reply With Quote
Old   February 9, 2018, 03:34
Nico B.
nbuchi is on a distinguished road
Hi, Zordiack,
I have adopted your viscous heating code in chtMultiRegionSimpleFoam. In addition, I implemented a temperature-dependent viscosity model.
My investigations deal with journal bearings. So I compared the calculation results with a state-of-the-art bearing program.
Standing now, I am very satisfied.
Thank you very much
nbuchi
nbuchi is offline   Reply With Quote
Old   May 12, 2022, 02:30
Amit Makhija
AMitgM95 is on a distinguished road
Could you please help in writing the viscous dissipation term in OpenFOAM v9? I tried but was unable to figure out how to write the expression for shear-stress symmetric tensor ((gradU + gradU.T())).
AMitgM95 is offline   Reply With Quote
calculating the viscous stress tensor tau for viscous dissipation heating dgadensg OpenFOAM Programming & Development 5 January 17, 2023 15:20
compressibleInterFoam incl. viscous dissipation heating vigges OpenFOAM Programming & Development 5 June 10, 2018 06:06
Viscous Heating of polymer in Ansys verdesca2 Structural Mechanics 0 August 21, 2014 10:50
viscous heating and constant wall temperature abir FLUENT 5 May 17, 2013 12:17
Viscous heating Pipin FLUENT 3 July 14, 2008 12:05
