Strange results using AMI. Meshing with Ansys.
Old   July 3, 2022, 16:58
Unhappy Strange results using AMI. Meshing with Ansys.
Anuar Giménez
anuargimenez is on a distinguished road
I am trying to use the Arbitrary Rotating AMI case to simulate a polymer flow through a single screw extruder, and I would really appreciate any help.
Previously, I have been able to successfully run the same case using the MRF approach, with good results.
The geometry is shown bellow:
Attachment 90568
The mesh was generated using ANSYS. Then, I used the topoSet utility to create the rotating and stationary cellZone, and also the faceZone needed to develop the AMI patches.
The topoSetDict file is shown bellow:
|  \\    /   O peration     | Version:  dev                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
        name    rotif;
        type    cellSet;
        action  new;
        source  cylinderToCell;
        sourceInfo
	    p1          (0 0.004 0);
	    p2          (0 0.043703 0);
	    radius      0.00396;
        name    outerCells;
        type    cellSet;
        action  new;
        source  cellToCell;
        sourceInfo
            set rotif;
        name    outerCells;
        type    cellSet;
        action  invert;
        name    rotif;
        type    cellZoneSet;
        action  new;
        source  setToCellZone;
        sourceInfo
            set     rotif;
        name    rotifFace;
        type    faceSet;
        action  new;
        source  cellToFace;
        sourceInfo
            set     rotif;
            option  all;
        name    rotifFace;
        type    faceSet;
        action  subset;
        source  cellToFace;
        sourceInfo
            set     outerCells;
            option  all;
        name    rotif;
        type    faceZoneSet;
        action  new;
        source  setsToFaceZone;
        sourceInfo
            faceSet     rotifFace;
            cellSet     rotif;
Finally, with the createBaffles utility I defined the AMI patches as follows:
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  7
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createPatchDict;
internalFacesOnly true;
baffles
    rotating
        type        faceZone;
        zoneName    rotif;
        patches
            master
                name            AMI1;
                type            cyclicAMI;
                neighbourPatch  AMI2;
                transform       rotational;
          	 rotationAxis    (0 1 0);
      		 rotationCentre  (0 0 0);
            slave
                name            AMI2;
                type            cyclicAMI;
                neighbourPatch  AMI1;
This is the script I used to run the case:
#!/bin/sh
cd ${0%/*} || exit 1    # Run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
application=$(getApplication)
runApplication fluentMeshToFoam AMI.msh
#Create cellZones and faceZones for rotating mesh. Develop new AMI BC´s
runApplication topoSet
runApplication createBaffles -overwrite
runApplication mergeOrSplitBaffles -split -overwrite
# Renumbering for speeding up simulation
runApplication renumberMesh -noFields -overwrite
decomposePar
pyFoamPlotRunner.py mpirun -np 6 rhoPimpleFoam -parallel
echo "Done!"
Here you can see the AMI patches:
Attachment 90570
and the velocity field obtained in the rotating cellZone:
Attachment 90569
As you can see, the velocity field seems wrong. In my MRF simulation the effect of the rotation due to the screw was very clear. With the AMI approach it seems that the highest velocity values are at the inlet, which is an unreal result.
I hope anyone could give me some advice or correct me if there is any error. I have little experience using AMI.
Kind Regards,
Anuar R. Giménez El Amrani
anuargimenez is offline   Reply With Quote
Old   July 4, 2022, 07:23
Hasan Celik
PositronCascade is on a distinguished road
Have you tried recent Non-Conformal Coupling?
Source
PositronCascade is offline   Reply With Quote
Old   July 4, 2022, 16:53
Anuar Giménez
Source
Thank you very much for you quick response. I didn't heard before about NCC.
However, I need to run it in the OpenFoam-7 version, so im afraid that I can not use it.
May I ask if anything about my AMI procedure or code looks strange to you?
Kind Regards,
Anuar
ami, ansys, mrf, openfoam
[swak4Foam] reconstructPar error in MRFsimpleFoam (ami apprach) using GroovyBC velocity inlet Krao OpenFOAM Community Contributions 3 August 19, 2019 05:40
[ANSYS Meshing] Can start ANSYS meshing only one time on ubuntu 16.04 Touré ANSYS Meshing & Geometry 2 September 26, 2017 05:41
Meshing on hpc using ansys mesh AS_Aero CFX 13 April 3, 2017 19:05
2-way FSI in Ansys CFX 15 LucasGasparino CFX 3 August 6, 2015 03:17
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 01:10
