IOerror when using function objects in debug-mode |
July 6, 2022, 13:04 |
Rep Power: 4 |
Hello friends,
facts:
whenever I try to use function objects in my simulation I get error message below: Code:
... Courant Number mean: 0 max: 0 Starting time loop --> FOAM FATAL IO ERROR: error in IOstream "OSHA1stream.sinkFile_" for operation Ostream& operator<<(Ostream&, const char) file: OSHA1stream.sinkFile_ at line 0. From function virtual bool Foam::IOstream::check(const char*) const in file db/IOstreams/IOstreams/IOstream.C at line 96. FOAM exiting Code:
functions { myFunction { // I can write whatever I want in here, the error will occur anyway. type whateverFunction; functionObjectsLibs (...); ... } }; The error occurs when OF tries to read the sub-dictionary for functions. I did some debugging and found out that the error originates (if I can say so) in the read() function of functionObjectList.C, line 799 when dict.digest() is called. I marked the exact spot in the following code. Of course it goes down deeper into the code, but I can't really follow what's happening in there since I have no idea what SHA1 digests are: Code:
bool Foam::functionObjectList::read() { bool ok = true; updated_ = execution_; // Avoid reading/initialising if execution is off if (!execution_) { return true; } // Update existing and add new functionObjects const entry* entryPtr = parentDict_.lookupEntryPtr ( "functions", false, false ); if (entryPtr) { PtrList<functionObject> newPtrs; List<SHA1Digest> newDigs; HashTable<label> newIndices; label nFunc = 0; if (!entryPtr->isDict()) { FatalIOErrorInFunction(parentDict_) << "'functions' entry is not a dictionary" << exit(FatalIOError); } const dictionary& functionsDict = entryPtr->dict(); libs.open ( functionsDict, "libs", functionObject::dictionaryConstructorTablePtr_ ); newPtrs.setSize(functionsDict.size()); newDigs.setSize(functionsDict.size()); forAllConstIter(dictionary, functionsDict, iter) { const word& key = iter().keyword(); if (!iter().isDict()) { if (key != "libs") { IOWarningInFunction(parentDict_) << "Entry " << key << " is not a dictionary" << endl; } continue; } const dictionary& dict = iter().dict(); bool enabled = dict.lookupOrDefault("enabled", true); newDigs[nFunc] = dict.digest(); // in here something goes wrong. ... I already opened an issue on Github (https://github.com/OpenFOAM/OpenFOAM-9/issues/12), however, I think this community is probably more active. Any help is appreciated! Best regards Finn Last edited by finn_amann; July 7, 2022 at 02:33. Reason: clarification |
July 7, 2022, 08:07 |
Rep Power: 4 |
The problem has been solved in the latest commit by Henry Weller
(https://github.com/OpenFOAM/OpenFOAM...9a60e33ed456eb). Using git pull will get you the necessary update. |
July 8, 2022, 04:43 |
#3 | |
Mark Olesen
Rep Power: 40 |
https://develop.openfoam.com/Develop...4e1f9fee82b5c7 It aged fairly well, so I was also surprised by this too (I guess I didn't read the docs carefully enough the first time). Was solved about a month ago before the OpenFOAM-v2206 release (also included in the v1912, v2006, v2012, v2105, v2112 maintenance branches). https://develop.openfoam.com/Develop.../-/issues/2481 I'm still not sure how the "OpenFOAM Foundation Ltd." manages to justify laying copyright claim to this bit of code too. |
Calculating source term total cell-zone volume parallel computation | RobV | Fluent UDF and Scheme Programming | 2 | May 30, 2022 03:46 |
Foam-extend crashes with custom BC, but works fine in Debug mode | Arman_N | OpenFOAM Programming & Development | 7 | September 26, 2020 01:51 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
