Problems with implementing sink term in Gamma-Re-Theta turbulence model
Old   August 9, 2022, 14:27
Default Problems with implementing sink term in Gamma-Re-Theta turbulence model
Sumedh S.
sumedhss is on a distinguished road
Hello all,
I'm trying to augment the Gamma-Re-Theta model to include crossflow effects as per Langtry (Langtry, Robin. "Extending the gamma-rethetat correlation based transition model for crossflow effects." In 45th AIAA fluid dynamics conference, p. 2474. 2015.) In this approach, an additional sink term D_{SCF} is added to the transport equation for \tilde{Re_{\theta t}}, which is described as-
D_{SCF} = c_{\theta t}\frac{\rho}{t}min(Re_{SCF}-\tilde{Re_{\theta t}},0)F_{\theta t 2}
Here, Re_{SCF} is the stationery crossflow Reynolds number, which is computed implicitly using a correlation. Since Re_{\theta t 0} (freestream transition momentum thickness Reynolds number) is also computed implicitly, I defined Re_{SCF} in a similar fashion as
Re_{\theta t 0} and called it in
correctReThetatGammaInt()
, but I get the following warning while compiling-
In file included from ../turbulenceModels/lnInclude/kOmegaSSTLMN.H:320,
                 from turbulentTransportModels/myTurbulentTransportModels.C:60:
../turbulenceModels/lnInclude/kOmegaSSTLMN.C: In instantiation of ‘Foam::tmp<Foam::DimensionedField<double, Foam::volMesh> > Foam::RASModels::kOmegaSSTLMN<BasicTurbulenceModel>::ReSCF(const Internal&, const Internal&, const Internal&) const [with BasicTurbulenceModel = Foam::IncompressibleTurbulenceModel<Foam::transportModel>; Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Internal = Foam::DimensionedField<double, Foam::volMesh>]’:
../turbulenceModels/lnInclude/kOmegaSSTLMN.C:707:21:   required from ‘void Foam::RASModels::kOmegaSSTLMN<BasicTurbulenceModel>::correctReThetatGammaInt() [with BasicTurbulenceModel = Foam::IncompressibleTurbulenceModel<Foam::transportModel>]’
../turbulenceModels/lnInclude/kOmegaSSTLMN.C:785:5:   required from ‘void Foam::RASModels::kOmegaSSTLMN<BasicTurbulenceModel>::correct() [with BasicTurbulenceModel = Foam::IncompressibleTurbulenceModel<Foam::transportModel>]’
../turbulenceModels/lnInclude/kOmegaSSTLMN.C:768:6:   required from here
I tried running simulations with this model, but they would crash instantly with the error log mentioning Re_{SCF}. When I replaced Re_{SCF} with a constant value in
, the model compiles without issues and simulations also run without issues. It is clear that the problem is related to the instantiation of the function template, but I am not able to pinpoint the exact reason. I have attached the code and header file along with the post. I'm using OpenFOAM v2012. Any help on this topic would be sincerely appreciated.
Thanks a lot!
sumedhss is offline   Reply With Quote
Old   August 10, 2022, 06:10
Domenico Lahaye
dlahaye is on a distinguished road
Not sure.
Does its make sense to look into fvOptions to include an additional source term?
dlahaye is offline   Reply With Quote
Old   August 13, 2022, 03:34
Sumedh S.
Originally Posted by dlahaye View Post
Not sure.
Can fvOptions access protected member functions? All the constants required for the source terms are protected class members in this case.
Old   August 31, 2022, 10:24
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
You can redefine the constants in the coded FO.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
gamma rethetat, gamma theta model, transition model, transition sst, turbulence models
SST k-omega model, definition of gamma or alpha in the production term blyatman Main CFD Forum 13 October 25, 2022 20:13
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 18:19
Gamma Theta Model Error dl467 CFX 4 November 26, 2015 07:52
K - epsilon VS SST turbulence model Maicol Main CFD Forum 0 November 30, 2012 16:25
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
