September 27, 2022, 04:21 |
modified stochastic dispersion
Charles Guaquiere
Rep Power: 3 |
I try to modify stochastic dispersion model on Open FOAM to improved my results concerning particles deposition. I found a tutorial from Chalmers University: http://www.tfd.chalmers.se/~hani/kur..._Xu_Report.pdf I changed the stochasticDispersionRAS.C and the stochasticDispersionRAS.H like in the tutorial but it used Open FOAM 4 and I use Open FOAM 9. My problem is on the following part of the code (from line 21 to 33): Code:
yP_ ( IOobject ( "yP", this->owner_.mesh().time().timeName(), this->owner_.mesh(), IOobject::NO_READ, IOobject::AUTO_WRITE ), this->owner_.mesh(), dimensionedScalar("yP", dimless, 0.0) ) error_message.jpg I don't know what I need to modify to make it works on OpenFOAM 9. I have already tried several modifications, without success. I am new to programming on openFOAM so can anyone help me ? |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
Modified wave number: which one would affect dispersion error? | TurbJet | Main CFD Forum | 12 | May 17, 2019 16:59 |
DPM particle tracks with and without turbulence dispersion | sthinmind | FLUENT | 1 | April 3, 2018 09:56 |
Inclusion of Damping Function in Stochastic Dispersion Model | mayank.dce2k7 | OpenFOAM Running, Solving & CFD | 0 | July 15, 2014 00:45 |
Turbulent Dispersion for Coal Combustion | gravis | CFX | 2 | March 23, 2010 23:56 |
