October 7, 2022, 22:21 |
Compile error
Ching Liu
Rep Power: 8 |
I am a beginner in OpenFOAM programming. To learn how to compile solvers, I did a simple test, but met an error.
I am using OpenFOAM v2012 installed on Windows 10. In the solver folders, there are many solvers. I copied the compressibleInterFoam solver and paste to the same folder, and renamed it compressibleInterFoam1. When I compile the compressibleInterFoam1, I have an error as follows: /opt/OpenFOAM/OpenFOAM-v2012/wmake/wmake: line 637: make: command not found /opt/OpenFOAM/OpenFOAM-v2012/wmake/wmake: line 640: make: command not found wmake error: file '/opt/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/applications/solvers/multiphase/compressibleInterFoam1/sourceFiles' could not be created in /opt/OpenFOAM/OpenFOAM-v2012/applications/solvers/multiphase/compressibleInterFoam1 Anyone knows what is the reason and how to fix it? |
October 8, 2022, 08:01 |
Ashutosh
Rep Power: 4 |
GNU make is not installed.
October 8, 2022, 13:33 |
Ching Liu
Rep Power: 8 |
Thanks. When I install GNU make using the command: apt install make. there is an error:
apt: /opt/OpenFOAM/OpenFOAM-v2012/ThirdParty/platforms/linux64/gcc-6.3.0/lib64/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /lib/x86_64-linux-gnu/libapt-pkg.so.6.0) It shows that GLIBCXX_3.4.26' not found. Do you know what I need to do next? |
October 9, 2022, 01:09 |
Ashutosh
Rep Power: 4 |
libstdc++6 is not installed. You also need install build-essential.
compile error, openfoam |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
