Compile error
Old   October 7, 2022, 22:21
Default Compile error
Ching Liu
qingqingliu is on a distinguished road
I am a beginner in OpenFOAM programming. To learn how to compile solvers, I did a simple test, but met an error.
I am using OpenFOAM v2012 installed on Windows 10. In the solver folders, there are many solvers. I copied the compressibleInterFoam solver and paste to the same folder, and renamed it compressibleInterFoam1. When I compile the compressibleInterFoam1, I have an error as follows:
/opt/OpenFOAM/OpenFOAM-v2012/wmake/wmake: line 637: make: command not found
/opt/OpenFOAM/OpenFOAM-v2012/wmake/wmake: line 640: make: command not found
wmake error: file '/opt/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/applications/solvers/multiphase/compressibleInterFoam1/sourceFiles' could not be created in /opt/OpenFOAM/OpenFOAM-v2012/applications/solvers/multiphase/compressibleInterFoam1
Anyone knows what is the reason and how to fix it?
qingqingliu is offline   Reply With Quote
Old   October 8, 2022, 08:01
Ashutosh
night-hawk is on a distinguished road
GNU make is not installed.
night-hawk is offline   Reply With Quote
Old   October 8, 2022, 13:33
Ching Liu
Thanks. When I install GNU make using the command: apt install make. there is an error:
apt: /opt/OpenFOAM/OpenFOAM-v2012/ThirdParty/platforms/linux64/gcc-6.3.0/lib64/libstdc++.so.6: version `GLIBCXX_3.4.26' not found (required by /lib/x86_64-linux-gnu/libapt-pkg.so.6.0)
It shows that GLIBCXX_3.4.26' not found. Do you know what I need to do next?
Old   October 9, 2022, 01:09
Ashutosh
libstdc++6 is not installed. You also need install build-essential.
compile error, openfoam
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
