Run-time Code Compilation in controlDict
Old   February 7, 2012, 04:40
Default Run-time Code Compilation in controlDict
JNSN's Avatar
Jan
JNSN is on a distinguished road
Hi Foamers,
I try to implement a variable time Step in the controlDict with the #codeStream directive based on the actual time. Something like
this->db().time().value()
produces the error massage "invalid use of ‘this’ in non-member function". Does anyone have an idea to get a reference to time?
Thanks and best regards,
Jan
JNSN is offline   Reply With Quote
Old   October 16, 2022, 22:53
xinyu
lliyuu is on a distinguished road
May I ask if you have solved this problem? I have also encountered this problem.
lliyuu is offline   Reply With Quote
Old   October 17, 2022, 10:46
JNSN's Avatar
Jan
sorry, but It's has been to long, can't remember. But as far as I know, there is now a functionObject available to control the time step. May this is helpful for your requirements.
Best,
Jan
Old   October 17, 2022, 21:08
xinyu
Thank you very much for your help. I will try this method.
Old   October 17, 2022, 23:51
Tatsuya Shimizu
LongGe is on a distinguished road
Originally Posted by JNSN View Post
Hi Foamers,
Jan
Hi
Can't you access time() of db() with the following code?
const IOdictionary& d = static_cast<const IOdictionary&>(dict);
scalar t = d.db().time().value();
Our Work: https://www.idaj.co.jp/product/ennovacfd/openfoam_gui/
Powered by Ennova : https://ennova-cfd.com/
Ennova's Channel Partners : http://www.wolfdynamics.com/
LongGe is offline   Reply With Quote
Old   October 19, 2022, 04:15
xinyu
Thank you very much for your help. I'm a novice. I've tried this method. It works. Why?
I can use scalar t=this ->db(). time(). value() in the u file;
However, it is not allowed in the coalcloudproperties file.
In addition, vectorField&field=* this; The same problem will arise.
liyuu
Old   October 24, 2022, 05:23
xinyu
Originally Posted by LongGe View Post
Hi
liyuu
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Run time Selection Mechanism - Some help required to understand jaswi OpenFOAM Programming & Development 3 October 29, 2015 13:42
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
