One dimensional array in OF21(Segmentation fault (core dumped)) |
December 21, 2022, 14:03 |
Farzad Faraji
Rep Power: 7 |
Hello all
I am defining a one dimensional parameter which has 2 million elements; Code:
int nCounter = U.size(); Info << "1" << endl; scalar AAAA[nCounter]; for(int i=0; i<nCounter; i++) { AAAA[i] = 0;} Code:
1 Segmentation fault (core dumped) |
December 21, 2022, 19:45 |
#2 | |
Farzad Faraji
Rep Power: 7 |
I afraid that maybe i counter goes beyond the limits so I change it to
for(int i=1 i<100; i++) { AAAA[i] = 0;} Thanks, Farzad Quote:
December 22, 2022, 05:00 |
Mark Olesen
Rep Power: 40 |
I don't understand the source of your error, but there is no reason to be using raw C arrays instead of an OpenFOAM list or even a std vector. Give the following a try:
scalarField AAA(U.size()); for (label i=0; i < AAA.size(); ++i) { AAA[i] = 0; } Code:
scalarField AAA(U.size(), Zero); |
December 22, 2022, 13:22 |
#4 | |
Farzad Faraji
Rep Power: 7 |
Thanks a lot for your advice. I did it like this as you said and it works;
int nCounter = U.size(); scalarField AAA(nCounter); and since I need it to set zero every time step, I set it zero like this every time step; Code:
for(int i=0; i<nCounter; i++) {AAA[i] = 0;} Thanks, Farzad Quote:
December 23, 2022, 01:50 |
#5 | |
Rep Power: 4 |
You can either use the vectorized method to make the for loop obsolete (but I think the compiler automatically using SIMD and might be that an overloaded operator[] will prohibit this operation) or I know for the GeometricField<T> class there is an overloaded operator= which sets the whole Field with a particular value. Since GeometricField is inhereting from Field class (if you go for Field<scalar>) I think there should be something similiar Code:
AAA[:] = 0 //vectorized // works at least for GeometricField<T> AAA = dimensionedScalar(dimless, 0.0) //sets .ref and .boundaryFieldRed to 0 |
array, error, fault, of21, segmentation |
[OpenFOAM] Paraview segmentation fault core dumped | GLfast80 | ParaView | 0 | March 13, 2021 12:53 |
Segmentation fault (core dumped) | prashantgoel | CONVERGE | 2 | May 26, 2020 12:48 |
SU2-7.0.1 on ubuntu 18.04 | hyunko | SU2 Installation | 7 | March 16, 2020 04:37 |
Segmentation fault (core dumped) | Sugajen | OpenFOAM Running, Solving & CFD | 1 | August 2, 2017 12:06 |
solving a conduction problem in FLUENT using UDF | Avin2407 | Fluent UDF and Scheme Programming | 1 | March 13, 2015 02:02 |
