error: ‘mesh’ was not declared in this scope
Old   September 26, 2023, 10:17
Default error: ‘mesh’ was not declared in this scope
Saeed Jamshidi
saeed jamshidi is on a distinguished road
Hi all,
I wanna utilized the codestream for my simulation. To this end, I have prepared "S" dictionary, which calculates the curl of velocity in computaional domain.
|  \\    /   O peration     | Version:  v2112                                    |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      S;
dimensions      [0 0 0 0 0 0 0];
internalField      #codeStream
    libs    ("utilityFunctionObjects.so");
    codeInclude
        #include "fvCFD.H"
	codeOptions
		-I$(LIB_SRC)/finiteVolume/lnInclude \
		-I$(LIB_SRC)/meshTools/lnInclude
	codeLibs
		-lmeshTools  \
		-lfiniteVolume
	code
		volScalarField S
			IOobject
				"S",
				mesh().time().timeName(),
				mesh(),
				IOobject::READ_IF_PRESENT,
				IOobject::AUTO_WRITE
			mesh(),
			dimensionedScalar("S", dimensionSet(0, 0, 0, 0, 0, 0, 0), Zero)
		const objectRegistry& db();
		const volVectorField& U = db().lookupObject<volVectorField>("U");
		const fvMesh & mesh = U.mesh();
		// Create a scalar field that contains the volume of each cell within the mesh
		const scalarField& v = mesh().V();
		// Calculate the curl of the flow and then take the magnitude of it
		const volScalarField& magCurlU = mag(fvc::curl(U));
		forAll(S, celli)
			// For curl of velocity, use the line below
			S[celli] = pow(v[celli], 1.0/3.0) * magCurlU[celli];
		S.writeEntry("", os);
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            zeroGradient;
    top
        type            zeroGradient;
    Bottom
        type            zeroGradient;
    cylinder
        type            zeroGradient;
    frontAndBack
        type            empty;
but, when i run it in openfoam i see some errors:
/home/myfoam/OpenFOAM/myfoam-v2112/run/tutorials/incompressible/pimpleFoam/LES/cylinder/0/S.#codeStream:47:5: error: ‘mesh’ was not declared in this scope
/home/myfoam/OpenFOAM/myfoam-v2112/run/tutorials/incompressible/pimpleFoam/LES/cylinder/0/S.#codeStream:47:5: note: suggested alternative: ‘cosh’
/usr/lib/openfoam/openfoam2112/wmake/rules/General/transform:34: recipe for target 'Make/linux64GccDPInt32Opt/codeStreamTemplate.o' failed
make: *** [Make/linux64GccDPInt32Opt/codeStreamTemplate.o] Error 1
--> FOAM FATAL IO ERROR: (openfoam-2112 patch=220610)
Failed wmake "dynamicCode/_52a2dbf780a8697296fac2199c6f254fa84ab80e/platforms/linux64GccDPInt32Opt/lib/libcodeStream_52a2dbf780a8697296fac2199c6f254fa84ab80e.so"
file: 0/S at line 17.
    From static void (* Foam::functionEntries::codeStream::getFunction(const Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
    in file db/dictionary/functionEntries/codeStream/codeStream.C at line 192.
FOAM exiting
I would appreciate it if you helpe me to solve this problem.
thanks.
saeed jamshidi is offline   Reply With Quote
#codestream, internal field
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
