May 7, 2023, 22:03 |
How to access all the processors in wsl
Parth
Rep Power: 5 |
I am using Hp Z6 G4 workstation. It have two processors each with 20 physical cores in it but the lscpu on wsl only detects the one processor, due to which i am not able to fully utilize all the physical cores of system.
I am getting this on lscpu postanddelete.jpg PLEASE HELP I am expecting a code or steps to configure wsl so it can access all the processors in my workstation |
May 17, 2023, 12:08 |
Klaus
Rep Power: 22 |
It's probably an OS (Windows) specific problem most likely caused by a driver conflict or you're using a Windows version that doesn't support 2 sockets. Apparently Windows "Home" editions don't support 2 sockets while "Professional" editions do - double check your version specific socket support before spending money on an upgrade and remember that Linux doesn't have this problem and is free and can be installed using a dual boot configuration (I would recommend to install Linux on a separate/additional drive).
April 24, 2024, 20:43 |
#3 | |
FaridElson
Rep Power: 2 |
May 4, 2024, 00:18 |
#4 | |
Xinze
You may find what you need here: https://github.com/sirredbeard/WSL2-more-cores |
wsl |
parallel run in foam extend | CRI_CFD | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 5 | March 28, 2024 08:36 |
Get list of shared points by neighbor processors with same order | andpush | OpenFOAM Programming & Development | 0 | June 18, 2019 04:19 |
Socket 2011-3 processors - an overwiew | flotus1 | Hardware | 10 | June 17, 2017 09:47 |
Is there a way to access the gradient limiter in Fluent ? | CFDYourself | FLUENT | 1 | February 16, 2016 05:49 |
64-bit processors for home computing | Ananda Himansu | Main CFD Forum | 2 | March 16, 2004 12:48 |
