Add mass source term to simpleFoam
Old   February 5, 2022, 12:45
Default Add mass source term to simpleFoam
MamboJambo is on a distinguished road
I would like to add a mass source term to simpleFOAM but do not know how to do it.
Can I just create a field called mass term:
volScalarField massSource
    IOobject
        "massSource",
        runTime.timeName(),
        mesh,
        IOobject::MUST_READ,
        IOobject::AUTO_WRITE
    mesh
And add it to pEqn.H line 28 as:
        fvScalarMatrix pEqn
            fvm::laplacian(rAtU(), p) == fvc::div(phiHbyA) - massSource
Is this correct?
I was going to set the values of massSource from `setExprFields`.
Is this the correct procedure? Does the momentum equation need to changed?
MamboJambo is offline   Reply With Quote
Old   May 10, 2023, 04:56
DuanYabo
DuanYB is on a distinguished road
Hello, I encountered the same problem as you, and I corrected it in the same way as you, but the program reported an error. Have you solved it now?
DuanYB is offline   Reply With Quote
How to add Source term (2) for PYROLYSIS - reactingOneDim Kummi OpenFOAM 10 April 12, 2021 21:11
Add a mass source/sink to simpleFoam palarcon OpenFOAM Programming & Development 4 May 15, 2019 02:33
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
