How to work with third order (rank 3) tensor fields in openFOAM?
Old   August 20, 2015, 22:45
Default How to work with third order (rank 3) tensor fields in openFOAM?
Fernando Soares Alves
FernandoSoares is on a distinguished road
Hi there Foamers,
I was wondering if it is already available in openFOAM a class which deals with tensor fields of rank higher than 2. As a matter of fact, I've found this old thread here in the forum.
Since it is from 2009 I would like to know if openFOAM (foam extend) has finally implemented the TensorThirdField and SymmTensorThirdField classes mentioned in the Programmer's guide P-27 and P-33.
Just contextualizing what I'm working with I would like to take the gradient of the symmetric part of the velocity gradient. Well I would also like to take the triple product of the velocity field, e.g. something like U*U*U.
Many thanks in advance,
F. Soares
FernandoSoares is offline   Reply With Quote
Old   July 5, 2023, 17:03
Default Hello
Khaled
elbatawy is on a distinguished road
Have you reached anything with your issue ? because i have the same issue
elbatawy is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
OpenFOAM does not work any more! kiddmax OpenFOAM Installation 12 June 25, 2013 02:56
problem in exporting stl files from solid work to openfoam reza1980 OpenFOAM 2 April 25, 2013 17:37
2nd order boundary conditions for 2nd order discretization? quarkz Main CFD Forum 30 December 26, 2011 07:12
OpenFOAM 2.0.0. and 2.0.1 doesn't work in parallel mode rv82 OpenFOAM Running, Solving & CFD 3 October 3, 2011 10:47
