undefined "dictionaryConstructorTablePtr_'" when switching from 2006 to 2012 |
March 7, 2024, 11:19 |
Bruno Chareyre
I am trying to compile a code which compiles with OFoam 2006 (I'm speaking of precompiled packages for ubuntu 22.04) but not with newer versions. I bissected it, the problem appeared with 2012 and it remains with all subsequent versions. I checked the release notes but I did not see anything in obvious relation with the linker error below. Is anyone aware of why it occurs and how to fix this? (I must say that I am not an experienced user of OFoam). The file to be compiled is pimpleFoamYade.C from [1]. Version 2006: Code:
source /usr/lib/openfoam/openfoam2006/etc/bashrc ./Allwmake --> no issue Then: Version 2012 Code:
source /usr/lib/openfoam/openfoam2012/etc/bashrc ./Allclean ./Allwmake ... ... ... g++ -std=c++14 -m64 -pthread -DOPENFOAM=2006 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offset of -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I./DPMTurbulenceModels/lnInclude -I/usr/lib/openfoam/openfoam2006/src/transportM odels/compressible/lnInclude -I/usr/lib/openfoam/openfoam2006/src/transportModels -I/usr/lib/openfoam/openfoam2006/src/transportModels/incompressible/singlePhaseTr ansportModel -I/usr/lib/openfoam/openfoam2006/src/TurbulenceModels/turbulenceModels/lnInclude -I/usr/lib/openfoam/openfoam2006/src/TurbulenceModels/incompressible/ lnInclude -I/usr/lib/openfoam/openfoam2006/src/TurbulenceModels/phaseIncompressible/lnInclude -I/usr/lib/openfoam/openfoam2006/src/finiteVolume/lnInclude -I/usr/li b/openfoam/openfoam2006/src/meshTools/lnInclude -I../FoamYade/lnInclude -I../FoamYade/meshtree -I/usr/lib/openfoam/openfoam2006/src/Pstream/mpi/ln Include -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/usr/lib/x86_64-linux-gnu/openmpi/include -I/usr/lib/x86_64-linux-gnu/openmpi/include/openmpi -std=gnu++0x -iquote . -IlnInclude -I/usr/lib/openfoam/openfoam2006/src/OpenFOAM/lnInclude -I/usr/lib/openfoam/openfoam2006/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPInt32Opt/pimpleFoamYade.o -L/usr/lib/openfoam/openfoam2006/platforms/linux64GccDPInt32Opt/lib \ -lincompressibleTransportModels -lturbulenceModels -lincompressibleTurbulenceModels -lDPMTurbulenceModels -lfiniteVolume -lfvOptions -lmeshTools -L/home/3S-LAB /username/OpenFOAM/username-v2006/platforms/linux64GccDPInt32Opt/lib -lMeshTree -lYadeFoam -L/usr/lib/openfoam/openfoam2006/platforms/linux64GccDPInt32Opt/li b/openmpi-system/lPstream -L/usr/lib/x86_64-linux-gnu/openmpi/lib -lmpi -lOpenFOAM -ldl \ -lm -o /home/3S-LAB/username/OpenFOAM/username-v2006/platforms/linux64GccDPInt32Opt/bin/pimpleFoamYade /usr/bin/ld: pimpleFoamYade.C:(.text._ZN4Foam15TurbulenceModelINS_17geometricOneFieldENS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEENS_32incompressibleRhoTu rbulenceModelENS_25singlePhaseTransportModelEE3NewERKS1_RKS5_RKNS2_INS_6VectorIdEES3_S4_EERKNS2_IdNS_13fvsPatchFieldENS_11surfaceMeshEEESM_RKS7_RKNS_4wordE[_ZN4Foa m15TurbulenceModelINS_17geometricOneFieldENS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEENS_32incompressibleRhoTurbulenceModelENS_25singlePhaseTransportModel EE3NewERKS1_RKS5_RKNS2_INS_6VectorIdEES3_S4_EERKNS2_IdNS_13fvsPatchFieldENS_11surfaceMeshEEESM_RKS7_RKNS_4wordE]+0x31e): undefined reference to `Foam::TurbulenceMo del<Foam::geometricOneField, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::incompressibleRhoTurbulenceModel, Foam::singlePhaseTransportMod el>::dictionaryConstructorTablePtr_' collect2: error: ld returned 1 exit status [1] https://gitlab.com/yade-dev/Yade-Ope...ref_type=heads Last edited by bchareyre; March 11, 2024 at 07:27. |
March 10, 2024, 15:28 |
Mark Olesen
Rep Power: 40 |
Linker errors are always fun. I don't think that anything changed in the OpenFOAM runtime selection tables that would affect you (those changes came later for the 2106 and/or 2112 releases).
In any case, it could be helpful if you installed an openfoam2312-dev so that any errors would be closer to a fresh release. I'm not saying that this will solve your problem, or that someone else will solve it immediately, but at least makes it easier for others to reproduce the issue without having to go back to a version that is several years old. |
March 11, 2024, 07:25 |
Bruno Chareyre
Thank you for feedback.
I pasted the output of the first failing version since all higher versions give exactly the same linker error. You are right about raising attention on latest version though. So here it is: Code:
source /usr/lib/openfoam/openfoam2312/etc/bashrc ./Allwmake -lincompressibleTransportModels -lturbulenceModels -lincompressibleTurbulenceModels -lDPMTurbulenceModels -lfiniteVolume -lfvOptions -lmeshTools -L/home/username/OpenFOAM/username-v2312/platforms/linux64GccDPInt32Opt/lib -lMeshTree -lYadeFoam -L/usr/lib/openfoam/openfoam2312/platforms/linux64GccDPInt32Opt/lib/sys-openmpi/lPstream -L/usr/lib/x86_64-linux-gnu/openmpi/lib -lmpi -lOpenFOAM -ldl \ -lm -o /home/username/OpenFOAM/username-v2312/platforms/linux64GccDPInt32Opt/bin/pimpleFoamYade /usr/bin/ld: Make/linux64GccDPInt32Opt/pimpleFoamYade.o: in function `Foam::TurbulenceModel<Foam::geometricOneField, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::incompressibleRhoTurbulenceModel, Foam::singlePhaseTransportModel>::New(Foam::geomet ricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::singlePhaseTransportModel const&, Foam::word const&)': pimpleFoamYade.C:(.text._ZN4Foam15TurbulenceModelI NS_17geometricOneFieldENS_14GeometricFieldIdNS_12f vPatchFieldENS_7volMeshEEENS_32incompressibleRhoTu rbulenceModelENS_25singlePhaseTransportModelEE3New ERKS1_RKS5_RKNS2_INS_6VectorIdEES3_S4_EERKNS2_IdNS _13fvsPatchFieldENS_11surfaceMeshEEESM_RKS7_RKNS_4 wordE[_ZN4Foam15TurbulenceModelINS_17geometricOneFieldEN S_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshE EENS_32incompressibleRhoTurbulenceModelENS_25singl ePhaseTransportModelEE3NewERKS1_RKS5_RKNS2_INS_6Ve ctorIdEES3_S4_EERKNS2_IdNS_13fvsPatchFieldENS_11su rfaceMeshEEESM_RKS7_RKNS_4wordE]+0x272): undefined reference to `Foam::TurbulenceModel<Foam::geometricOneField, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::incompressibleRhoTurbulenceModel, Foam::singlePhaseTransportModel>::dictionaryConstr uctorTable(Foam::word const&)' /usr/bin/ld: pimpleFoamYade.C:(.text._ZN4Foam15TurbulenceModelI NS_17geometricOneFieldENS_14GeometricFieldIdNS_12f vPatchFieldENS_7volMeshEEENS_32incompressibleRhoTu rbulenceModelENS_25singlePhaseTransportModelEE3New ERKS1_RKS5_RKNS2_INS_6VectorIdEES3_S4_EERKNS2_IdNS _13fvsPatchFieldENS_11surfaceMeshEEESM_RKS7_RKNS_4 wordE[_ZN4Foam15TurbulenceModelINS_17geometricOneFieldEN S_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshE EENS_32incompressibleRhoTurbulenceModelENS_25singl ePhaseTransportModelEE3NewERKS1_RKS5_RKNS2_INS_6Ve ctorIdEES3_S4_EERKNS2_IdNS_13fvsPatchFieldENS_11su rfaceMeshEEESM_RKS7_RKNS_4wordE]+0x4fe): undefined reference to `Foam::TurbulenceModel<Foam::geometricOneField, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::incompressibleRhoTurbulenceModel, Foam::singlePhaseTransportModel>::dictionaryConstr uctorTablePtr_' collect2: error: ld returned 1 exit status make: *** [/usr/lib/openfoam/openfoam2312/wmake/makefiles/general:174: /home/username/OpenFOAM/username-v2312/platforms/linux64GccDPInt32Opt/bin/pimpleFoamYade] Error 1 |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
LEMOS InflowGenerator | r_gordon | OpenFOAM Running, Solving & CFD | 103 | December 18, 2018 00:58 |
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 | Attesz | OpenFOAM Installation | 45 | January 13, 2012 12:38 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 00:34 |
