Using boxtocell in custom solver to obtain a list of cells |
March 8, 2024, 07:09 |
Divyaprakash
Rep Power: 11 |
I have read that boxtocell is a utility that is used to select cells in a bounding box during preprocessing.
I need the same functionality but inside the custom solver that I am writing. In it, at every time step the origin of the bounding box would change. I looked at the source code of boxtocell.C but I am unable to make sense of it since I am only a beginner in C++. Can someone please provide some pointers on how I would be able to access boxtocell as a function inside a C++ program? Some background information: Basically what I need is to get a list of cells in the neighborhood of a point. The method I am using now only gives me a list of the immediate neighbours. Code:
const Foam:point rr(0.05, 0.05, 0.005); // Define the point label cellIndex = mesh.findCell(rr); // Get the neighboring cells const Foam::labelList& neighbors = mesh.cellCells()[cellIndex]; I can use neighbours of neighbours to get more cells, but then that would lead to repition of cells. I am therefore thinking of using boxtocell as a function if that is possible. However if another method exists to solve this problem, then please do suggest. Last edited by Divyaprakash; March 8, 2024 at 07:20. Reason: more information |
March 10, 2024, 07:40 |
Shravan
Rep Power: 9 |
I will try to explain to you how the boxToCell code works, with this you can fit the logic inside your solver. I will use Foundation version 9 for an example here https://cpp.openfoam.org/v9/boxToCell_8H_source.html https://cpp.openfoam.org/v9/boxToCell_8C_source.html In order to understand the meaning of the variables and member functions in the .C file, take a look at the .H file carefully. These variables are initialized or assigned values using the Constructors (in the .C file). Here you have 2 public member functions and 1 private member function. The public member function that does the operation of setting the values to the desired box is applyToSet(). So first take a look at that member function applyToSet(). It basically adds or removes cell centers by calling the private member function combine(). And the combine() member function basically chooses the necessary box which you would like to patch using setFields. So the combine() member function is the one that you should be looking carefully into, for your purpose. So, now lets try to understand what combine() does. I have commented the lines below for you to understand better Code:
void Foam::boxToCell::combine(topoSet& set, const bool add) const { const pointField& ctrs = mesh_.cellCentres(); // Store the cell centres in your mesh in ctrs forAll(ctrs, celli) // Loop over the cell centres { forAll(bbs_, i) // Loop over the coordinates that you intend to patch inside (which has been specified in setFields - see that bbs_ is read from the dictionary, so it takes the coordinate values from setFields file) { if (bbs_[i].contains(ctrs[celli])) // If your cell centre from the mesh (ctrs) lies inside the block that you like to patch (bbs_) { addOrDelete(set, celli, add); // Defined in class topoSetSource break; } } } } https://cpp.openfoam.org/v9/boxToCell_8H.html https://cpp.openfoam.org/v9/boxToCell_8C.html I see that it is a little different for the ESI version, but if you try to understand along the lines I have mentioned, you should be able understand how it is implemented in the ESI version, and eventually put it in your code. Also look at the ESI user guide to understand better: https://www.openfoam.com/documentati...boxToCell.html Good luck! |
boxtocell, setfields, toposet |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
Compiling custom solver for profiling | rku | OpenFOAM Programming & Development | 0 | June 24, 2021 04:12 |
Error with custom solver simulation | heitorvitorc | OpenFOAM Running, Solving & CFD | 0 | April 21, 2019 13:05 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
Problems with running a custom solver: "Unknown psiCombustionModel" | AlexKam | OpenFOAM Programming & Development | 25 | November 23, 2015 20:51 |
