How to handle inter-process communication before surf->reconstruct()? |
March 14, 2024, 22:52 |
zzt
I tried to use a pointer surf_ to point to the selected reconstruction scheme.
autoPtr<reconstructionSchemes> surf_; Then, from what I understand, surf->reconstruct() is used for surface reconstruction. I would like to use this method to obtain the surface mesh list, normal vector, etc. However, in parallel computing, how should I handle inter-process communication before surf->reconstruct()? Can anyone help to solve the issue? |
Calculating source term total cell-zone volume parallel computation | RobV | Fluent UDF and Scheme Programming | 2 | May 30, 2022 03:46 |
Communication Deadlock in MPPICFoam Parallel Solver | auburnhpc | OpenFOAM Running, Solving & CFD | 1 | May 29, 2021 16:55 |
Parallel fluent process exiting before reading the mesh file | harsha2398 | FLUENT | 3 | December 29, 2020 00:58 |
The fl process could not be started because of UDF | majid_kamyab | Fluent UDF and Scheme Programming | 6 | December 15, 2015 08:42 |
[Netgen] meshing process stops (after surf meshing?) | vaina74 | OpenFOAM Meshing & Mesh Conversion | 5 | May 27, 2011 02:32 |
