March 21, 2024, 10:40 |
Issue with buoyantSimpleFoam
Nicolas Poupelin
Rep Power: 2 |
Hello everyone,
I'm a beginner with open foam, but I would have liked to be able to calculate pmv and ppd, but before I could get them, I made an error in my calculation: buoyantSimpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _7bdb509494-20201222 OPENFOAM=2012 Arch : "LSB;label=32;scalar=64" Exec : buoyantSimpleFoam Date : Mar 21 2024 Time : 15:18:51 Host : DESKTOP-LBS0ECK PID : 53069 I/O : uncollated Case : /mnt/c/Users/Nicopoup/tutorial/confort nProcs : 1 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: no convergence criteria found. Calculations will run for 0.5 steps. Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState { type perfectGas; } specie { nMoles 1; molWeight 28.97; } energy { type heTotalEnergy; specificHeat Cp [ 0 2 -2 -1 0 0 0 ] 1000; } } --> FOAM FATAL IO ERROR: (openfoam-2012) Attempt to return dictionary entry as a primitive file: /mnt/c/Users/Nicopoup/tutorial/confort/constant/thermophysicalProperties.thermoType.energy at line 27 to 28. From virtual Foam::ITstream& Foam::dictionaryEntry::stream() const in file db/dictionary/dictionaryEntry/dictionaryEntry.C at line 82. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::IOerror::exitOrAbort(int, bool) at ??:? #2 Foam::dictionaryEntry::stream() const at ??:? #3 Foam::word Foam::dictionary::get<Foam::word>(Foam::word const&, Foam::keyType:ption) const at ??:? #4 Foam::HashTable<Foam::autoPtr<Foam::rhoThermo> (*)(Foam::fvMesh const&, Foam::word const&), Foam::word, Foam::string::hash>::iterator Foam::basicThermo::lookupThermo<Foam::rhoThermo, Foam::HashTable<Foam::autoPtr<Foam::rhoThermo> (*)(Foam::fvMesh const&, Foam::word const&), Foam::word, Foam::string::hash> >(Foam::dictionary const&, Foam::HashTable<Foam::autoPtr<Foam::rhoThermo> (*)(Foam::fvMesh const&, Foam::word const&), Foam::word, Foam::string::hash>*) at ??:? #5 Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMe sh const&, Foam::word const&) at ??:? #6 Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:? #7 ? at ??:? #8 ? in /lib/x86_64-linux-gnu/libc.so.6 #9 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #10 ? at ??:? Aborted I would like to know how to correct the code so that it works. Thank you in advance |
March 21, 2024, 10:42 |
More informations
Nicolas Poupelin
Rep Power: 2 |
For informations, here's the code I use :
#!/bin/bash # Définition des chemins vers les exécutables OpenFOAM # source $HOME/OpenFOAM/OpenFOAM-v2012/etc/bashrc echo "source /opt/OpenFOAM/OpenFOAM-v2012/etc/bashrc" >> ~/.bashrc source $HOME/.bashrc # Se déplacer dans le répertoire de travail cd /mnt/c/Users/Nicopoup/tutorial/confort # Définition des variables room_width=7.52 room_length=8.01 room_height=3.0 total_heat_loss=2814 wall_temperature=18.77 air_temperature=19.23 # Propriétés de base de l'air # Remplacer les valeurs par celles appropriées air_density=1.2 # kg/m^3 air_viscosity=1.8e-5 # m^2/s air_thermal_conductivity=0.026 # W/(m*K) # Génération de la géométrie blockMesh # Configuration des conditions aux limites pour la température # Les conditions de température sont définies dans le fichier 0/T # Assurez-vous de remplacer les valeurs par celles appropriées echo "FoamFile" > 0/T echo "{" >> 0/T echo " version 2.0;" >> 0/T echo " format ascii;" >> 0/T echo " class volScalarField;" >> 0/T echo " object T;" >> 0/T echo "}" >> 0/T echo >> 0/T echo "dimensions [0 0 0 1 0 0 0];" >> 0/T echo >> 0/T echo "internalField uniform 300;" >> 0/T echo >> 0/T echo "boundaryField" >> 0/T echo "{" >> 0/T echo " wall" >> 0/T echo " {" >> 0/T echo " type fixedValue;" >> 0/T echo " value uniform $wall_temperature;" >> 0/T echo " }" >> 0/T echo " inletOutlet" >> 0/T echo " {" >> 0/T echo " type inletOutlet;" >> 0/T echo " inletValue uniform $air_temperature;" >> 0/T echo " }" >> 0/T echo " // Ajouter d'autres conditions aux limites si nécessaire" >> 0/T echo "}" >> 0/T echo >> 0/T # Configuration des conditions aux limites pour la vitesse d'air # Les conditions de vitesse d'air sont définies dans le fichier 0/U # Assurez-vous de remplacer les valeurs par celles appropriées # Configuration des propriétés du fluide # Propriétés de l'air echo "transportModel Newtonian;" > constant/transportProperties echo "nu nu [ 0 2 -1 0 0 0 0 ] $air_viscosity;" >> constant/transportProperties echo "Pr Pr [ 0 0 0 0 0 0 0 ] 0.7;" >> constant/transportProperties # Propriétés thermophysiques de l'air echo "thermalModel Newtonian;" > constant/thermophysicalProperties echo "rho rho [ 1 -3 0 0 0 0 0 ] $air_density;" >> constant/thermophysicalProperties echo "Cp Cp [ 0 2 -2 -1 0 0 0 ] 1000;" >> constant/thermophysicalProperties echo "kappa kappa [ 1 -1 -3 0 0 0 0 ] $air_thermal_conductivity;" >> constant/thermophysicalProperties # Exécution de la simulation buoyantSimpleFoam # Post-traitement des résultats # Vous pouvez post-traiter les résultats pour extraire des données pertinentes # telles que la température, la vitesse de l'air, etc. # Calcul des indices PMV et PPD postProcess -func 'PMV()' -time 'latestTime' postProcess -func 'PPD()' -time 'latestTime' # Visualisation des résultats sur Paraview paraFoam |
March 21, 2024, 11:30 |
#3 | |
Ching Liu
Rep Power: 8 |
March 21, 2024, 11:35 |
File
Nicolas Poupelin
Rep Power: 2 |
Hello, the file in question is:
FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object thermophysicalProperties; } thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState { type perfectGas; } specie { nMoles 1; molWeight 28.97; } energy { type sensibleInternalEnergy; // Changed type to sensibleInternalEnergy specificHeat Cp [ 0 2 -2 -1 0 0 0 ] 1000; } } transportModel Newtonian; nu nu [ 0 2 -1 0 0 0 0 ] 1.8e-5; Pr Pr [ 0 0 0 0 0 0 0 ] 0.7; rho rho [ 1 -3 0 0 0 0 0 ] 1.2; Cp Cp [ 0 2 -2 -1 0 0 0 ] 1000; kappa kappa [ 1 -1 -3 0 0 0 0 ] 0.026; |
March 21, 2024, 11:58 |
#5 | |
Ching Liu
Rep Power: 8 |
March 21, 2024, 12:32 |
Nicolas Poupelin
Rep Power: 2 |
I've just tried it and unfortunately it didn't work.
Issue on zeroGradient BC for system rotation | magnushaese | OpenFOAM Running, Solving & CFD | 2 | January 28, 2022 13:43 |
Request for dictionary failed with buoyantSimpleFoam | sturgeon | OpenFOAM Running, Solving & CFD | 4 | January 21, 2021 06:26 |
rhoCentralFoam inviscid airfoil issue (Foam::error::printStack(Foam::Ostream&) at ??) | kmkb21 | OpenFOAM Running, Solving & CFD | 1 | March 1, 2018 01:07 |
Simulation of Water with buoyantSimpleFoam possible? | BenFranklinIII | OpenFOAM Running, Solving & CFD | 0 | July 24, 2015 05:57 |
Pressure boundary condition issue | Vijay | FLUENT | 0 | April 6, 2012 13:35 |
