Accessing Inter-cell convection
Old   March 25, 2024, 09:26
Default Accessing Inter-cell convection
Sereff
Sereff is on a distinguished road
Dear Foamers,
I am working on a solver for a chemical reaction.
fvScalarMatrix YiEqn
    fvm::ddt(Yi)
  + fvm::div(phi, Yi)
  - fvm::laplacian(Deff, Yi)
    fvOptions(Yi)
  + reaction->R(i)
And for one of the reactions, in order to calculate the source term R(i), I would need the information of the convection of the species of each cell with its surrounding cells and boundaries. I am aware that there's
fvm::div(phi, Yi)
but I need the information as a volScalarField or GeometricField<scalar>. And the adorementioned term is operating on a fvScalarMatrix, which contains a lot more information and I am not sure how to extract the information i want. Could someone help me on this issue?
kind regards,
Sereff is offline   Reply With Quote
Old   March 25, 2024, 13:39
Shravan
Severus is on a distinguished road
You can use fvc instead.
For example the continuity error is calculated in a similar fashion
 volScalarField contErr(fvc::div(phi));
See line 33: https://cpp.openfoam.org/v9/src_2fin...8H_source.html
Thanks
Severus is offline   Reply With Quote
Old   March 26, 2024, 11:21
Sereff
Thank you Severus, and I guess if I use
fvc::div(phi,Yi)
then it would give me the convection of species Yi for all cells?
kind regards,
Old   March 27, 2024, 10:32
Shravan
Yes you should get whole field values (i.e. for all cells).
Thanks
Accessing local cell index with global cell index in functionObject Shibi OpenFOAM Programming & Development 2 May 18, 2021 11:16
how to evaluate where UDM is failing tricha122 FLUENT 4 June 18, 2020 13:45
accessing internal cell gradient field at boundary when applying boundary condition vishalsacharya OpenFOAM Programming & Development 7 February 25, 2019 15:36
Accessing neighboring cells' cell number Daniel Lattin Siemens 4 October 20, 2006 16:19
Accessing Neighbouring Cell info Murali Siemens 1 December 9, 2002 06:10
