Access to particles diameter for turbulent dispersion
Old   April 9, 2024, 12:07
Default Access to particles diameter for turbulent dispersion
Charles Guaquiere
CGuaq is on a distinguished road
Dear Foamers,
I try to optimize my new model for turbulent dispersion on particles and I need to know the size of each particles to modify their turbulent fluctuating velocity depending on their size.
Until now I manually specified the particle size in my code (assuming a constant size). But in a case where I have a distribution in size it's not possible to use this method without errors for the prediction.
I tried to add the following line at the beginning of the function to calculate the turbulent fluctuating velocity:
    const typename CloudType::parcelType& p,
    const scalar dt,
    const label celli,
    const vector& U,
    const vector& Uc,
    vector& UTurb,
And in my code to specify the diameter:
 const scalar dp = p.d();
This method is used in the Brownian motion code (../src/lagrangian/parcelTurbulence/submodels/Thermodynamic/ParticleForces/BrownianMotion), I can compile the code with these lines but when I launch the simulation I have an error at the injection time of the particles. Did I forget something or is it just impossible to use these lines in the turbulent dispersion code ?
Thus how can I access the particle size in my code ? Do you have another method?
Thanks for your help.
CGuaq is offline   Reply With Quote
Number of Particles distribution in a chamber using flow simulation - how? teleguy FloEFD, FloWorks & FloTHERM 0 January 24, 2021 11:27
Color DEM particles according to their diameter zcheng STAR-CCM+ 1 May 28, 2020 05:04
access to velocity gradient for Lagrangian particles jiejie OpenFOAM 31 December 2, 2016 04:56
Add lagrangian particles to OpenFoam solver luchen2408 OpenFOAM 0 June 2, 2015 03:10
Access precalculated k-field in lagrangian dispersion model oswald OpenFOAM Programming & Development 0 September 3, 2013 11:25
