How to obtain initial condition in codedFixedValue boundary condition |
April 29, 2024, 10:34 |
Junyu Ni
Rep Power: 3 |
Hi, everyone. I want to achieve a particular dynamic boundary that is coupled with fluid pressure and dependent on initial geometry.
In a brief form, the boundary displacement satisfies the equation +=-p,where is the displacement along the initial normal direction of the wall(here it is a cylinder), and p is the fluid pressure. I use the dynamicMotionSolverFvMesh as dynamicFvMesh and displacementLaplacian solver. In the pointDisplacement dictionary, I set the moving boundary as the codedFixedValue type and try to solve the above equation. Now I need to obtain the normal direction at the initial time. I don't know which patch I should use. By the way, I found a 'points0' in the displacementLaplacian that seems to be the initial position, but it seems not accesible directly. I have the following codes to obtain pressure on the boundary at present Time: Code:
const fvMesh& mesh = this->patch().boundaryMesh().mesh(); label cylinderID = mesh.boundaryMesh().findPatchID("cylinder"); volScalarField& tempP = mesh.lookupObjectRef<volScalarField>("p"); const fvPatchScalarField& cylinderP = tempP.boundaryField()[cylinderID]; |
codedfixedvalue, displacementlaplacian, dynamic boundary, dynamic mesh, initial mesh |
foam extend solid contact simulation blow up | CRI_CFD | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 4 | February 28, 2023 04:54 |
Compressible flows with larger Courant numbers | Tobi | OpenFOAM Running, Solving & CFD | 5 | February 26, 2021 15:20 |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. | Nkl | OpenFOAM Running, Solving & CFD | 19 | October 10, 2019 02:42 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
