OpenFOAM not recognize custom library (decomp method) |
May 8, 2024, 18:31 |
Erik Nijkamp
Rep Power: 2 |
I am struggling with adding a custom decomp method to OpenFOAM. This library successfully complies to a .o object, and further to a .so object. However, it does not show up as an option when using DecomposePar. Perhaps its relevant that I am using foam-extend4.1. For simplicity, I was just trying to get a new decomp method called metisDecomp2, which is just the same as metisDecomp, but I just want to show that something new can be added. So I copied the metisDecomp/ folder, renamed it to metisDecomp2/, and renamed all the files, and moved it to the $FOAM_USER_LIBBIN I crtl+F metisDecomp and replaced it with metisDecomp2 in the C and H file, to make the new class. I updated the Make/files, Make/options, and CMakeLists.txt as shown below. Make/files: Code:
metisDecomp2.C LIB = $(FOAM_USER_LIBBIN)/libmetisDecomp2 Make/options: Code:
EXE_INC = \ -I$(METIS_INCLUDE_DIR) \ -I$(FOAM_SRC)/decompositionMethods/lnInclude \ -I$(FOAM_SRC)/scotchDecomp/lnInclude LIB_LIBS = \ -ldecompositionMethods \ -L$(FOAM_LIBBIN)/dummy \ -L$(METIS_LIB_DIR) -lmetis and the CMakeLists.txt Code:
list(APPEND SOURCES metisDecomp2.C ) add_foam_library(metisDecomp2 SHARED ${SOURCES}) target_link_libraries(metisDecomp2 PUBLIC decompositionMethods metis2) After I do all this, and put the option metis2, it says: Code:
Unknown decompositionMethod metis2 Valid decompositionMethods are : 8 ( engineScotch hierarchical manual metis parMetis patchConstrained scotch simple ) I assume that I am missing something small and simple. I have never added my own custom lib. Thanks for your time looking over my question. If you need any more clarification, please let me know. Best, Erik |
May 21, 2024, 15:27 |
Klaus
Rep Power: 22 |
I had a look at the decomposePar.C... sources and Make files, according to that "EXE = $(FOAM_APPBIN)/decomposePar" it's meant to be an application, not a library.
The best way to start developing new things in OpenFOAM is to copy the most similar application or library, change the name compile and run it under the new name, if that works, make your changes and compile your new application or library. For applications use wmake and wclean, for libraries use wmake libso and wclean libso. Custom libraries need to be added to the control dictionary as follows: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2312 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // libs ("libMyLibraryName.so"); ... |
May 23, 2024, 02:16 |
#3 | |
Mark Olesen
Rep Power: 40 |
It is indeed relatively simple. You have compiled a new library (libmetisDecomp2) and presumably also included the addToRunTimeSelectionTable interface in the code (otherwise none of this will work). The missing piece of the puzzle is that this library actually needs to be loaded when the application runs. You don't see this most of the time, since the library dependencies are usually defined when compiling the application (see decomposePar/Make/options). In your case, you need to specify the library loading. You can either quickly add a "libs" entry into your case controlDict, but it is usually easier just to use the '-lib' option, which is available for all OpenFOAM applications (eg, blockMesh -help-full for usage). To check that your library can actually load OK, without missing other dependencies, use the foamhasLibrary utility. |
decomposepar methods, libbin |
Reading rigidBody motion state from custom library | katiuskas | OpenFOAM Programming & Development | 2 | November 21, 2023 05:49 |
Duplicate library entries when running a solver with custom library | francescomarra | OpenFOAM Programming & Development | 3 | May 17, 2022 08:37 |
"Missing" files when implementing OpenFOAM dictionaries referenced in custom solver | markdeluca | OpenFOAM Programming & Development | 0 | December 2, 2018 16:58 |
HopeFOAM-0.1(Discontinuous Galerkin Method Extension of OpenFOAM) is released online! | ExerciseGroup | OpenFOAM Announcements from Other Sources | 3 | December 11, 2017 14:26 |
Building a custom solver on OpenFOAM 2.0 | wschosta | OpenFOAM Programming & Development | 1 | July 8, 2011 15:07 |
