Quentin
Rep Power: 17 ![]() |
Hi all,
in my study about a turbulent couette flow (including the energy equation for an incompressible flow) I would like to plot the heat flux in paraFoam (like U for instance). That's equivalent to plot the gradient of the temperature T. That's why I've tried to create a new field I call "gradT" which is a Volume vector Field and I've tried to solve the equation "gradT"=fvc::grad(T). But it doesn't work(It nevers works the first time ![]() Beta.C: In function ‘int main(int, char**)’: Beta.C:140: error: no matching function for call to ‘Foam::fvMatrix<Foam::Vector<double> >::fvMatrix(Foam::tmp<Foam::GeometricField<Foam::V ector<double>, Foam::fvPatchField, Foam::volMesh> >)’ And I want to solve the following equation: fvVectorMatrix gradTEqn ( gradT - fvc::grad(T) ); gradTEqn.solve(); Maybe is there a better way to plot the gradient? I hope you will have some hints concerning my operator error message. My regards Quentin P.S: I'm not sure if that's the good section of the forum. |
Try this: Code:
volVectorField gradT ( IOobject ( "gradT", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), fvc::grad(T) ); Jose Santos |
Quentin
Thanks Santos that was the command I required.
plot temperature gradient | isabel | CFX | 1 | October 6, 2008 22:51 |
How to plot pressure gradient in Fluent? | jrg | FLUENT | 3 | November 12, 2007 04:48 |
Adapt gradient and time plot. | Sham | FLUENT | 2 | April 14, 2005 12:43 |
plot the gradient for scalar | tseo | FLUENT | 1 | February 20, 2004 13:15 |
How to compute gradient for non-orthogonal grids? | Paul Hsieh | Main CFD Forum | 3 | November 11, 2003 04:52 |
