sonicFoam #include[s] rhoEqn.H...
Like Tree2Likes
  • 1 Post By l_r_mcglashan
  • 1 Post By JasonWang3
Old   January 29, 2010, 10:21
Default sonicFoam #include[s] rhoEqn.H...
Costas K
thekay is on a distinguished road
Send a message via ICQ to thekay Send a message via MSN to thekay
...but the rhoEqn.H cannot be found in the solver directory (version 1.6). I was curious when I was using the solver before, it gave results for everything, but the rho was always calculated as 0. Does anybody know the purpose of this? Is this intentional? Can I incorporate some other rhoEqn.H easily?
thekay is offline   Reply With Quote
Old   January 29, 2010, 11:55
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
It's in the folder OpenFOAM-1.6.x/src/finiteVolume/cfdTools/compressible.
Lisandro Maders likes this.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   February 15, 2010, 09:14
Costas K
Revisiting this thread after some time:
I am running a case at the moment, using sonicFoam. The case is pretty much the same as /home/username/OpenFOAM/OpenFOAM-1.6/tutorials/compressible/sonicFoam/ras/prism/ but instead of "prismWall", I have "wall" which is the wall of my domain. While running, in each time step, I get:
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
Obviously I don't have a rho file in 0/ but even if I do, I get the same output for rho.
My questions are:
  1. Can I get sonicFoam to solve for rho as well?
  2. Why is the above output produced? In no tutorial it solves for rho, so I am curious if it was just left there from another solver.
Thank you.
Old   April 26, 2010, 13:57
KGN
mecbe2002 is on a distinguished road
Any solution for this problem.
mecbe2002 is offline   Reply With Quote
Old   October 30, 2013, 04:17
Richard Mathie
RicMat is on a distinguished road
Probably you need to supply an equation of state in your case dir? that is dont you need a thermoPhysicalProperties dict? I cant say for shure as I am looking at engineFoam and rhoPimpleFOAM at the moment, but that seems to be what's happening there. rhoEqn.h is just the mass conservation equation.
RicMat is offline   Reply With Quote
Old   March 18, 2015, 11:58
Xinguang Wang
JasonWang3 is on a distinguished road
My questions are:
Thank you.
I met the same situation. sonicFoam is a pressure based solver, and the element of density don't need to solve alone. So that's maybe the reason of rho=0.
But still don't know how to get the rho values of the fields, two options:
1. state equation
2. phi=rho*velocity*A
JasonWang3 is offline   Reply With Quote
Old   October 2, 2015, 10:18
Default Solved?
Lisandro Maders
Lisandro Maders is on a distinguished road
Do you guys solved this issue? Why is rho equation not being calculated?
Lisandro Maders is offline   Reply With Quote
Old   October 5, 2015, 06:27
Xinguang Wang
Hi Maders
Try to add these extra sentence at the end of controlDict, and the rho will output in the calculation folder.
functions
rhofunc
type writeRegisteredObject;
functionObjectLibs ("libIOFunctionObjects.so");
outputControl outputTime;
outputInterval 1;
objectNames
"rho"
kcp18 likes this.
Old   October 5, 2015, 07:13
Default Worked!
Lisandro Maders
Originally Posted by JasonWang3 View Post
Hi Maders
Hi Wang,
that worked! I have already done it by inserting write() functions at runTime, but I found your way more straightforward.. Thanks!
Old   October 5, 2015, 07:18
Default Actually the answer is..
Lisandro Maders
Actually the main answer iin this topic was about the rho calculation.. That seemed not to be doing by the "0" values of iterations and residuals. Here is the aswer, which is very logic by the way: http://www.cfd-online.com/Forums/ope...opisofoam.html
Regards, Lisandro
Old   June 8, 2016, 17:45
Default Additional note
  #11
Kristopher Pierson
kcp18 is on a distinguished road
I would just like to add to this that by adding the rho function I was able to use the R utility to compute Reynolds stress when using the sonicFoam solver. This was very helpful if you are using some other turbulence model at the start of the solution with the intent to switch to LRR model after the flow field has been initialized.
kcp18 is offline   Reply With Quote
energy in sonicFoam joern OpenFOAM Running, Solving & CFD 1 September 24, 2019 00:15
Setting a case with sonicFoam achilleslaststand OpenFOAM Pre-Processing 0 December 4, 2009 11:29
define walls in sonicFoam shangzung OpenFOAM 0 October 21, 2009 08:18
Different response from 1.5 and 1.6 version of sonicFoam solver nishant_hull OpenFOAM Running, Solving & CFD 1 October 12, 2009 13:45
SonicFoam forwardStepTutorial doesnbt complete the run alberto OpenFOAM Bugs 1 June 10, 2007 15:35
