how to create a volScalarField of mesh.V() ???
Like Tree13Likes
  • 1 Post By sebware
  • 1 Post By Fransje
  • 7 Post By kathrin_kissling
  • 3 Post By mAlletto
  • 1 Post By raumpolizei
Old   July 8, 2010, 11:36
Default how to create a volScalarField of mesh.V() ???
Sebastian
sebware is on a distinguished road
Hey
I use a volScalarField with the volume of cells.
It works with the cell center but not with cell volume.
- Why the following line works
volVectorField centres = Sj.mesh().C();
- Why the following line dosn't work
volScalarField volume= Sj.mesh().V();
Sj is a volVectorField defined as follow:
volVectorField Sj
IOobject
"Sj",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
),mesh, dimensionSet(1,-1,-3,0,0,-1,0)
thanks
Sebastian
granzer likes this.
sebware is offline   Reply With Quote
Old   June 13, 2011, 12:59
Fran
lfbarcelo is on a distinguished road
Did you ever get to fix this? I have the exact same problem.
lfbarcelo is offline   Reply With Quote
Old   June 13, 2011, 17:20
Pablo
pablodecastillo is on a distinguished road
I think that mesh.V() is a scalarField, not a volscalarField ..........
pablodecastillo is offline   Reply With Quote
Old   July 2, 2011, 07:48
Francois
Fransje will become famous soon enough
Looking at the doxygen documentation on the openfoam.com website, you can see that:
const DimensionedField< scalar, volMesh > & V () const - Return cell volumes.
Meaning that V() will return a DimensionedField.
Did you try using:
volScalarField volume= Sj.mesh().V().field();
Kind regards,
Francois.
nimasam likes this.
Fransje is offline   Reply With Quote
Old   July 6, 2011, 10:17
Kathrin Kissling
kathrin_kissling is on a distinguished road
This is due that a volScalarField does store values on the boundary, what does not make a lot of sense for cell volumes.
So just the internalField of a volScalarField does have cell volumes
So I personally would not try to cast this into a volScalarField! What will you do on the boundaries? If you initialize the volScalarField with zero than there will be zero at the boundaries too. What happens if you divide at a point by these values?
I would just work on the internalField
volScalarField myWhatEverField =mag(U);
scalarField volumes = mesh.V();
volScalarField result(IOobject(...),mesh, 0);
result.internalField() = myWahateverField.internalField/volumes;
Do whatever you need to do on the boundaries
Best
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   July 22, 2018, 23:36
Elham
Elham is on a distinguished road
Best
Kathrin
I need mesh.V() for my code which is calculating mDot for phaseChangeTwoPhaseMixtures in a multi phase flow. There is the following error:
‘mesh’ was not declared in this scope
If I changee it to :
The error is :
‘const class Foam::incompressibleThreePhaseMixture’ has no member named ‘mesh’
I will aprrciateof any help.
Cheers,
Elham
Elham is offline   Reply With Quote
Old   July 29, 2018, 06:33
Michael Alletto
mAlletto will become famous soon enough
did you try U_.mesh().V()
mAlletto is offline   Reply With Quote
Old   November 12, 2018, 03:00
Elham
It didn't work.
Old   June 12, 2019, 03:17
Unhappy stuck in creating the volScalarField
krishna kant
kk415 is on a distinguished road
Hello All
I am trying to create a variable delta which is cuberoot of volume. I am using it in a coupled level set VOF method, inside the code I will be using the variable for some multiplication with volume fraction and level set scalar.
Here is the code I am using in createFields,
volScalarField deltaX
IOobject
"deltaX",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
mesh,
dimensionedScalar("deltaX",dimless, 0.0)
deltaX.internalField()=cbrt(mesh.V());
volScalarField gamma(deltaX*0.75);
volScalarField epsilon(deltaX*1.5);
volScalarField deltaTau(deltaX*0.1);
And it is giving the following error in the bold line
./createFields.H:228:27: error: passing ‘const Internal {aka const Foam:imensionedField<double, Foam::volMesh>}’ as ‘this’ argument of ‘void Foam:imensionedField<Type, GeoMesh>:perator=(const Foam::tmp<Foam:imensionedField<Type, GeoMesh> >&) [with Type = double; GeoMesh = Foam::volMesh]’ discards qualifiers [-fpermissive]
Any help will be deeply appreciated.
kk415 is offline   Reply With Quote
Old   June 12, 2019, 04:33
Michael Alletto
Did you try:
deltaX.primitiveFieldRef()=cbrt(mesh.V());
kk415, vivek05 and Zhanyuan Wang like this.
Old   June 14, 2019, 00:52
krishna kant
Thanks Michael,
It is working fine. But I have one more small doubt what is the difference between deltaX.primitiveFieldRef() and deltaX.Ref() ?
Old   June 14, 2019, 03:19
raumpolizei is on a distinguished road
Hey kk415,
it looks like your deltaX is having the wrong type of units (I don't know if dimless is what you want, shouldn't it be in [m]?). The reason why you were having the error is due to the fact that in OF (at least in my OF versions) the function internalField returns a const reference to a geometricFields private data which is storing the internal field, thus disallowing any kind of changes to that member. internalFieldRef is the non constant counterpart which allows you to modify the field directly. Regarding your last question, the function ref() returns a reference to the dimensioned internal field. So basically, by using this function, you may have to ensure that the dimensions of your field deltaX matches cbrt(mesh.V()) . It is basically safer. With internalFieldRef, you can write directly to that field without checking units. For more information, check the extended code guide (https://www.openfoam.com/documentati...ce.html#l00041) which is undoubtedly the best resource to better understand OF.
Cheers
RP
kk415 likes this.
raumpolizei is offline   Reply With Quote
Old   June 25, 2019, 03:34
Ruiyan Chen
cryabroad is on a distinguished road
Originally Posted by sebware View Post
Hey
volVectorField Sj
IOobject
"Sj",
runTime.timeName(),
mesh,
IOobject::NO_READ,
thanks
Sebastian
This is what I have been using.
voScalarField cellSize
    IOobject
        "cellSize",
        runTime.timeName(),
        mesh,
        IOobject::NO_READ,
    mesh,
    dimensionedScalar("zero", dimVolume, 0.0)
cellSize.ref() = mesh.V();
I think I actually got this piece of code by searching the forum. As others pointed out, mesh.V() doesn't store values corresponding to the boundaries, so whatever volScalarField you created to retrieve the cell volumes, you can only use the internal part.
cryabroad is offline   Reply With Quote
How to create initiate a volScalarField p without reading from disk NO_READ does not seem to work dbxmcf OpenFOAM Running, Solving & CFD 14 March 25, 2022 06:08
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 14:18
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
