scale(a, b) function
Like Tree3Likes
  • 3 Post By ngj
Old   August 31, 2010, 09:05
Default use of scale(a, b) function?? error: ‘scale’ was not declared in this scope
Ozgur Kirlangic
ozgur is on a distinguished road
In the Programmer’s Guide there is a description of a function named as scale:
As the name suggests, the scale function is a tool for scaling the components of one tensor by the components of another tensor of the same rank. It is evaluated as the product of corresponding components of 2 tensors, e.g., scaling vector a by vector b would produce vector c whose components are ci = scale(a, b) = (a1b1, a2b2, a3b3)
I have tried to use it however, I get the following error during compilation:
My code is simple:
#include "fvCFD.H"
vector a(1,2,3), b(4,5,6), c;
c=scale(a,b)
What can I do about this?
Thanks,
Ozgur
ozgur is offline   Reply With Quote
Old   August 31, 2010, 11:25
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Unfortunately the Programmers Guide is not up to date, as the function is now called "cmptMultiply".
Best regards,
Niels
sharonyue, mgg and yvesc like this.
ngj is offline   Reply With Quote
Old   September 1, 2010, 05:53
Ozgur Kirlangic
Hi Niels,
Thanks again
Ozgur
Old   December 31, 2012, 01:02
Nick
sunliming is on a distinguished road
Can cmptMultiply be used for scalarField, e.g. cmptMultiply(points1,points2) where type of points1 and points2 is scalarField?
sunliming is offline   Reply With Quote
Old   December 31, 2012, 09:19
ngj
Hi Nick,
You can just multiply two scalarFields with the operator "*", which result in a scalarField, so the cmptMultiply is not needed.
Happy New Year
Niels
Old   January 1, 2013, 02:11
Nick
Hi Niels,
Thank you! It's cool and convenient to use "*" for scalarField multiply. Sometimes it is just hard to access OpenFOAM for there are so few documents about how to operate field. And it's slow and inefficient to dig in the source code itself. If there are some instructions of handing fields, that would be better for OpenFAOM user programming!
Happy new year!
Nick
Old   May 26, 2014, 19:34
Default Thank you Niels
yves candau
yvesc is on a distinguished road
Best regards,
Niels
*sigh* this is 2013, and the Programmer's Guide is still not up-to-date.
Lost me 1/2 hour.
yvesc is offline   Reply With Quote
Old   August 27, 2015, 17:02
Paul W. Fontana
pfontana is on a distinguished road
How do you multiply a vector field by a scalar constant? If alpha is a const and U is a vector field (e.g. velocity), is it just cmptMultiply(U,alpha) or cmptMultiply(alpha,U)? (I tried just using a * U, but I got a compile-time error. The file createFields.H defines alpha as follows:
Info<< "Reading transportProperties\n" << endl;
IOdictionary transportProperties
IOobject
"transportProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ_IF_MODIFIED,
IOobject::NO_WRITE
dimensionedScalar alpha
transportProperties.lookup("alpha")
and the file transportProperties contains an entry for alpha (even though that shouldn't matter for compilation??):
alpha alpha [ 0 0 -1 0 0 0 0 ] 7.0;
The compile-time error I get is
fatal error: error in backend: IO failure on output stream.
pfontana is offline   Reply With Quote
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
