volScalarField
Old   November 17, 2010, 15:57
Default volScalarField
Diego Villa
DiegoNaval is on a distinguished road
HI all,
I have a little problem with a volScalarField, I have create that field in a class where is not defined the runTime object, but I want create a volScalarField that than I fill in that way:
__________________________________________________ ______
volScalarField alfa
IOobject
"alfa",
fileName(),
mesh_,
IOobject::NO_READ,
IOobject::NO_WRITE
mesh_
forAll(cells, i)
label lab=cells[i];
if(IntCell_[lab])
alfa.internalField()[lab]=1;
else
alfa.internalField()[lab]=0;
All can be compiled but when I run the solver that use that class I have that error:
| \\ / O peration | Version: 1.7.x |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 1.7.x-a654f2c8b4fb
Exec : MYMRFSimpleFoam
Date : Nov 17 2010
Time : 15:30:43
Host : salaria
PID : 11695
Case : /home/diego/OpenFOAM/diego-1.7.x/run/VerificaMRF/SimplePropeller
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
alphaK1 0.85034;
alphaK2 1;
alphaOmega1 0.5;
alphaOmega2 0.85616;
gamma1 0.5532;
gamma2 0.4403;
beta1 0.075;
beta2 0.0828;
betaStar 0.09;
a1 0.31;
c1 10;
Starting time loop
Time = 1
--> FOAM FATAL ERROR:
NO_READ specified for read-constructor of object alfa of class IOobject
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 46.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/diego/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/diego/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::regIOobject::readStream() in "/home/diego/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#3 Foam::regIOobject::readStream(Foam::word const&) in "/home/diego/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) in "/home/diego/OpenFOAM/diego-1.7.x/applications/bin/linux64GccDPOpt/MYMRFSimpleFoam"
#5 Foam::MRFZone::correctVelocityEquation(Foam::fvMat rix<Foam::Vector<double> >&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&) const in "/home/diego/OpenFOAM/diego-1.7.x/applications/bin/linux64GccDPOpt/MYMRFSimpleFoam"
#6 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/diego/OpenFOAM/diego-1.7.x/applications/bin/linux64GccDPOpt/MYMRFSimpleFoam"
#7 main in "/home/diego/OpenFOAM/diego-1.7.x/applications/bin/linux64GccDPOpt/MYMRFSimpleFoam"
#8 __libc_start_main in "/lib/libc.so.6"
#9 Foam::regIOobject::writeObject(Foam::IOstream::str eamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "/home/diego/OpenFOAM/diego-1.7.x/applications/bin/linux64GccDPOpt/MYMRFSimpleFoam"
Aborted
Someone have an idea on which is the problem?
DiegoNaval is offline   Reply With Quote
Old   November 18, 2010, 03:49
Nima Samkhaniani
nimasam is on a distinguished road
ur ioDic difinition is ill, use something like this:
volScalarField alfa
IOobject
"alfa",
fileName(),
mesh_,
IOobject::NO_READ, // when u use no read u should initialize ur variable
IOobject::NO_WRITE
mesh_,
dimensionScalar ("alfa",dimensionSet (0,0,....), 0) // this is just for initializing
ok?
nimasam is offline   Reply With Quote
Old   November 18, 2010, 11:30
Diego Villa
Thank you very much nima,
Now it's work well.
Old   January 30, 2012, 09:06
Illya Shevchuk
linch is on a distinguished road
Hi all,
I have another question to this topic. In createField.H I create a volScalarField
volScalarField kappa
        IOobject
            "kappa",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        twoPhaseProperties.kappa()
The class twoPhaseProperties is of the type compressibleTwoPhaseMixture, which I implemented analog to the twoPhaseMixture class. In the implementation of the class I have following lines:
tmp<volScalarField> compressibleTwoPhaseMixture::kappa() const
    return tmp<volScalarField>
        new volScalarField
            "kappa",
            limitedAlpha1*kappaModel1_->kappa()
            + (scalar(1) - limitedAlpha1)*kappaModel2_->kappa()
Such implementation can be found in the original twoPhaseProperties.C. Because new volScalarField has the same name "kappa" it somehow overwrites the option IOobject::AUTO_WRITE, and the volScalarField is not written. This does'n happen if I implement it in the following way.
So my questions are:
1) Does the first implementation allocate a new memory block for the whole volScalarField, even if the volScalarField kappa already exists? I would waste memory if so.
2) Where and why the IOobject::AUTO_WRITE is being overwritten?
3) Is the second implementation write? Does it have any drawbacks?
Best regards,
Ilya
linch is offline   Reply With Quote
Old   January 30, 2012, 11:58
David Gaden
marupio is on a distinguished road
1) Yes. Not only that, it creates a totally independent object that contains only the initial values of kappa. These values will never change throughout your simulation.
2) Probably gets overwritten in the GeometricField constructor. You can look through the list of constructors and choose one that suits you.
3) ?
What are you trying to achieve? Do you want kappa written out at every timestep, when it normally doesn't? I don't know how the mixture models work. You could use your first implementation, except change the constructor you use. Maybe give it a dimensioned scalar instead of the whole field.
    IOobject
    mesh,
    dimensionedScalar
        "kappa",
        twoPhaseProperties.kappa().dimensions(),
        0.0
Then, just before runTime.write(), update your output field by setting kappa equal to twoPhaseProperties.kappa().
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   February 1, 2012, 13:42
Illya Shevchuk
Thank you David for the reply!
Really? I thought the values will be updated each time I call twoPhaseProperties.kappa()
Exactly.
Well, kappa is different in each cell (e.g. it could be pressure or temperature dependent), thus volScalarField is ok. My goal is to make my two phase properties library, which is generally usable. One could either use the properties directly (e.g. fvm::laplacian(twoPhaseProperties.kappaf(),T) ) or to update an already existing field (e.g. kappa = twoPhaseProperties.kappa()). In the last case I want to prevent the double usage of memory. But I'm not sure if my second variant is right:
        new volScalarField
            "kappa",
Best regards,
Ilya
Old   February 1, 2012, 13:49
David Gaden
You are still creating a volScalarField, just using a different constructor that doesn't read from a file. The dimensionedScalar you define is the initial value throughout. This is a good constructor to use.
I'm sorry I didn't notice this: your kappa() function returns tmp<>. It is a temporary object. There is no permanent storage for kappa, therefore you aren't being wasteful by keeping a copy at the solver level. But you need to keep it up to date at every timestep before runTime.write() by setting it equal to the result of the function call as I suggested above.
Old   February 2, 2012, 03:04
Illya Shevchuk
Thanks once again David.
Could you please tell why?
That's clear.
How to create initiate a volScalarField p without reading from disk NO_READ does not seem to work dbxmcf OpenFOAM Running, Solving & CFD 14 March 25, 2022 06:08
if-loop, volScalarField comparison volker OpenFOAM 7 March 6, 2020 20:03
Problems with creating a volScalarField georlade OpenFOAM Programming & Development 4 December 4, 2016 12:31
Fill a volScalarField DiegoNaval OpenFOAM Programming & Development 6 November 19, 2010 09:26
dimensioned volScalarField lions85 OpenFOAM 1 November 12, 2009 02:41
