solve equation
Old   November 30, 2010, 11:09
Default solve equation
Diego Villa
DiegoNaval is on a distinguished road
Hi all,
I have a stupid question but I don't find the solution.
I must solve the following equation:
U & grad(eta) - Uz=0
where eta is a scalar field and U is velocity vector and Uz is the z-component of U.
How can I write the scalar matrix etaEqn and solve it?
Thanks.
DiegoNaval is offline   Reply With Quote
Old   November 30, 2010, 12:08
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi, Is your U field divergence free [div(U)==0]???, in this case you have
U & grad(eta) - Uz=0 -> div(U eta)-Uz=0
so that in FOAM
solve(fvm::div(phi,eta)-U.component(vector::Z)==0);
where phi is previously defined as phi=U&Sf, like is scalarTransportFoam, icoFoam, etc.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   November 30, 2010, 12:15
One more thing, Is your equation dimensionally consistent?
Best.
Research Scientist
Old   November 30, 2010, 13:45
Diego Villa
Thank you Santiago Marquez Damian
I solve like you suggest and it works.
Info<<"Inizio calcolo Matrice Eta"<<endl;
faScalarMatrix etaEqn
fam::div(phis,eta)
Info<<"Inizio Relax"<<endl;
etaEqn.relax();
Info<<"Inizio Solve"<<endl;
solve(etaEqn == (Us & aMesh.faceAreaNormals()));
Dimensionally is consistent because eta is a areaSaclarField and U is a areaVectorField.
But now I have an other problem, I use as linear solver the
eta smoothSolver
smoother DILU;
tolerance 1e-06;
relTol 0;
and as boundary condition:
in
type fixedValue;
value uniform 0;
out
type zeroGradient;
carena
type zeroGradient;
far
type zeroGradient;
but after few iteration the solution explode, do you think I make some macroscopical error? I use also a relax factor of 0.3 for the etaEqn.
Thanks.
Old   November 30, 2010, 13:59
I don't know, may be you can post the console output at the exploding moment and some data about the physical problem.
Regards.
Research Scientist
Old   November 30, 2010, 15:46
Diego Villa
I find the problem is the div shemes, I use a Gauss Linear and all explode, than I change in a Upwind and all works fine!!!
Thank for the help.
equation, solve
Q: how to solve linear equation dut_thinker FLOW-3D 2 September 2, 2010 22:17
Poisson equation combined with transport equation Se-Hee CFX 0 December 27, 2007 01:00
Solve Poissons Equation Anil CFX 8 September 25, 2007 12:57
How to solve a scalar equation with Fluent Tomik FLUENT 1 January 8, 2006 06:18
how to solve an equation at an interface sreenivas CFX 0 May 14, 2004 09:35
