How to add a source term (body force) to icoFoam?
Like Tree4Likes
  • 2 Post By chris Liu
  • 1 Post By nakul
  • 1 Post By gironidegirona
Old   December 6, 2010, 01:46
Default How to add a source term (body force) to icoFoam?
刘会星
chris Liu is on a distinguished road
Hi, foamers:
I am a new OpenFOAM user, and i want to add a source term (body force) to icoFoam.
I creat a new field named "F" and add F to the N-S equation. After complie, i test it in the lid-driven-cavity example, and use the force on the lid to drive the fluid instead of the lid velocity. However, the fluid stay still and the force fill the cavity.(I want the force on the lid only and the fluid is driven.)
Any suggestions will be appreciated!
Best regards!
chris Liu
createFields.H
// add source term;
Info<< "Reading field F\n" << endl;
volVectorField F
IOobject
"F",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
icoFoam-force.C
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
- fvm::laplacian(nu, U)
solve(UEqn == F -fvc::grad(p)); //add source term;
Detailed source file in the attachment.
Prosper and rasool_soofi like this.
chris Liu is offline   Reply With Quote
Old   December 6, 2010, 09:18
Nakul
nakul is on a distinguished road
Hi
If you need the force to be applied only on the lid then you have to define it as a boundary condition.
What you have done is that you have defined F as a volume field, i.e., on your mesh domain.
If you want to involve body force effects try buoyant solvers or define a new BC specific to your case.
Yage likes this.
nakul is offline   Reply With Quote
Old   December 7, 2010, 02:57
刘会星
Hi, nakul
Thank you for your advice!
I find that my expression was inconsistent.
The body force is a non-uniform field and depend on two factors, the distance to the patch and the orientation of the cell surface on the patch (e.g. lid). The body force (Lorentz force) is used to control the flow.
I will try the buoyant solves and post it here if i work it out.
Best regards
chris Liu
Old   February 17, 2012, 07:51
Default Did It work
Janez Turk
Janez Turk is on a distinguished road
Did it work?
how did you get incompressibility with body force?
LP Janez
Janez Turk is offline   Reply With Quote
Old   October 27, 2014, 15:38
Default I'm trying to the same thing!
gironidegirona is on a distinguished road
Hi chris Liu,
I'm trying to do the same thing, I want to add a source term into the transport equation. It is like a dragging force in the middle of the region.
I don't know how to implement that,
Can you give us a clue how you did it?
Thanks!
Prosper likes this.
gironidegirona is offline   Reply With Quote
Add a source term to simpleFoam markc OpenFOAM 9 September 10, 2009 10:55
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
Problems with SUPG body force term FEM question Main CFD Forum 0 January 21, 2006 17:51
