calculate surface area
Like Tree1Likes
  • 1 Post By santiagomarquezd
Old   December 6, 2010, 06:37
Default calculate surface area
Duong A. Hoang
duongquaphim is on a distinguished road
Send a message via Yahoo to duongquaphim
Deal OpenFOAM User,
I am implementing PLIC in interFOAM. Then I need to find the way to calculate the volume of each liquid occupied in each cell. I found in the primitiveMesh class two functions that can help me:
void Foam: primitiveMesh::makeFaceCentresAndAreas ( const pointField& p, vectorField& fCtrs, vectorField& fAreas )
and
void Foam: primitiveMesh::makeCellCentresAndVols ( const vectorField& fCtrs, const vectorField& fAreas, vectorField& cellCtrs, scalarField& cellVols )
However, I have a problem with construct pointField p in function
makeFaceCentresAndAreas. Let's say we have four points:
(1 0 0)
(2 0 0)
(2 1 0)
(1 2 0)
Does anyone have ideas about how to construct variable p from these four points for the input of this function?
Regards,
Duong
duongquaphim is offline   Reply With Quote
Old   December 6, 2010, 12:26
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi Duong, what about doing,
volScalarField alpha1Vol=mesh.V()*alpha1;
volScalarField alpha2Vol=mesh.V()*(scalar(1)-alpha1);
or something like this.
Best.
mhgolestan likes this.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   December 7, 2010, 10:03
Duong A. Hoang
Hi Santiago,
Thanks for the suggestion. However, since I want to construct the interface which has a form n.x+const = 0 (n is the normal vector and x is the point), I should find value of the constant to ensure the conservation of volume fraction. Then, I must find a way to use those function.
Btw, I found how to construct this pointField p. What you can do is:
pointField& p(4,point(0,0,0));
p[0] = point(1,0,0);
p[1] = point(2,1,0);
etc..
That's how we define pointField in OpenFOAM.
Regards,
Duong
Old   December 7, 2010, 13:00
Aha, I see. My answer was related to "then I need to find the way to calculate the volume of each liquid occupied in each cell". I understand that you need to calculate a plane within a cell such as the sub-volumes would be equal to those are calculated by the formulas I exposed before...
Bye.
Research Scientist
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Export Cell Surface Area Thierros CFX 0 April 28, 2010 06:01
cell surface area in boundary.. Chiar FLUENT 0 March 7, 2007 03:53
How to calculate the cell area Le FLUENT 0 February 18, 2007 22:15
Compute total surface area of Dpm figo FLUENT 0 September 8, 2004 21:44
