Transport Equation for a scalar - Compressible Solver
Like Tree1Likes
  • 1 Post By l_r_mcglashan
Old   January 25, 2011, 13:22
Default Transport Equation for a scalar - Compressible Solver
alessio.nz's Avatar
Alex
alessio.nz is on a distinguished road
Hi, I am a beginner with OF and I am new in the programming of the code.
I have to modify XiFoam, premix solver for turbulent combustion (which is rhoPisoFoam without any combustion) adding simply a new scalar transport equation for a variable ''C".
The equation is on the form of:
d/dt(rho*C)+rho*Ud/dxj(C) - laplacian(rho*nu * C) = ST
where the ST is the source term for the scalar.
The solver XiFoam is composed on the following files:
bEqn.H
createFields.H
ftEqn.H
hEqn.H
huEqn.H
Make (directory)
pEqn.H
readCombustionProperties.H
UEqn.H
XiFoam.C
XiFoam.dep
1) I have changed the names regarding XiFoam in NewXiFoam and the path of compilation (make/files).
2)I have created the file "Ceqn.H" and typed the following code:
solve
fvm::ddt(rho, C)
+ fvc::div(phi, C)
- fvm::laplacian(nu, C) == f
where f is taken from a table.
2) on the NewXiFoam.C I have added the following script on the code at the beginning the PISO loop:
for (int corr=1; corr<=nCorr; corr++)
#include "pEqn.H"
#include "Ceqn.H"
turbulence->correct();
3)on the "createFields.H"
I have added the script :
Info<< "\nReading field C\n" << endl;
volScalarField C
IOobject
"C",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
Now everything should be done and after the compilation "wmake" it gives 1 error. Could you please tell if the steps for this compressible solver are the correct ones or not and what I should take car of.
Thanks,
alex
alessio.nz is offline   Reply With Quote
Old   January 26, 2011, 02:17
M. Mahdi Salehi
smehdi609 is on a distinguished road
It can be several things, like syntas error, unit error and so on. You should post that so that we can help you. BTW, I bet you are implmenting PCM-FPI.
smehdi609 is offline   Reply With Quote
Old   January 26, 2011, 03:46
Matthias Voß
mvoss is on a distinguished road
hi,
did you try a wclean before wmake? what is wmake complaining about?
how did you set up the table for "f"? I mean,... is it read from an external file?
neewbie
mvoss is offline   Reply With Quote
Old   January 26, 2011, 11:58
alessio.nz's Avatar
Alex
thanks to all of you! finally, after checking all things, I succeed!
Old   January 27, 2011, 04:39
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
The above equation does not match what you've programmed below:
solve
fvm::ddt(rho, C)
+ fvc::div(phi, C)
solefire likes this.
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   April 11, 2013, 09:04
Smile
Lorenzo Bartolucci
Barlo is on a distinguished road
I'm sorry Alex, I'm interested in change XiFoam solver too, could you post your "well-done" code below, please? Thank you
Lorenzo
Barlo is offline   Reply With Quote
dieselFoam problem!! trying to introduce a new heat transfer model vivek070176 OpenFOAM Programming & Development 10 December 23, 2014 23:48
compressible flow solver in OF1.6 mecbe2002 OpenFOAM 9 December 25, 2010 09:17
interFoam + a scalar transport equation CYMa OpenFOAM 1 May 11, 2010 03:50
Is it possible to influence the velocity of an scalar transport equation? jannnesss CFX 1 January 11, 2010 12:02
scalar advection-diffusion equation Darcy CFX 1 March 12, 2001 09:49
