smallestDist / y distance problem
Old   February 21, 2011, 05:54
Default smallestDist / y distance problem
romant's Avatar
Roman Thiele
romant is on a distinguished road
Hej,
I have noticed that the smallestDist function in the class cellDistFuncs
http://foam.sourceforge.net/docs/cpp...lDistFuncs.php
seems to calculate the smallest difference in a way that it gives the wrong distance. I attached a picture in order to show what I mean. The distance towards the center of the channel seems to be right, but when the distances of the cells closer to the wall are supposed to be calculated, they are not the what one expects. In the attached pictures, the only walls are the boundaries on top and bottom. And it reports the cells closest to the wall to have a distance of 1.08 mm. The whole channel on the other hand, as one can see, is only 5.4mm wide.
Does anybody know why this behavior is like this? It doesn't make sense to me.
~roman
romant is offline   Reply With Quote
Old   March 17, 2011, 07:32
jms
José
jms is on a distinguished road
Hi Roman,
I am struggling a lot with this issue too. Have you got any insight for that?
I am doing cfd around an airfoil and I need the correct value of this distance in order to calculate yPlus.
Keep me updated if you get sth! I will do so too!
Regards,
José
jms is offline   Reply With Quote
Old   March 17, 2011, 07:43
Default y plus calculations
romant's Avatar
Roman Thiele
Hej,
in case you want to calculate y plus for compressible flow and turbulence models with wall functions you should be able to do this with
yPlusRAS
or
yPlusLES
for LES turbulence models and Reynolds average turbulence models, respectively. For y plus calculations for low Reynolds number turbulence models, you might also wanna follow this thread here http://www.cfd-online.com/Forums/ope...us-values.html which deals with a new calculation tool for y plus. let's hope this might also get fixed in the new release of OF.
~roman
Old   March 17, 2011, 07:51
jms
José
Hi!
Thank you for your advice. I already know that. I am using RANS, so I started using yPlusRAS but it gives y* instead of y+ (see this thread if you want to read about this...).
Thus, I am using one code from one guy which is an adaptation of yPlusLES to RANS. here you can find it. To calculate y + as you can see in the thread I have sent to you you need the 1st cell height, i.e. I would need the tool you were referring to in the message running well.
Anyway...if you know how to fix this calculation of the nearWall tool, let me know!
Regards,
José
Old   March 17, 2011, 08:01
Default nearWall
romant's Avatar
Roman Thiele
I think one way to do this could be by taking the distance normal from the cellCenter (cell at the wall) to the faceCenter (wallpatch). Since the velocity is stored at the cell center, this should then give the velocity at the cell center of the first cell and your y distance from the wall.
~roman
Old   March 17, 2011, 08:07
jms
José
Thanks Roman. I know this, but I am not very into programming OpenFOAM, this is why I was looking for a code with this already implemented.
Thank you anyway,
Regards,
José
Old   March 17, 2011, 08:08
romant's Avatar
Roman Thiele
maybe I will try this out soon, but unfortunately I don't have too much time at the moment. Hopefully, over the coming weeks I will be able to do some more programming.
~roman
Heat Transfer problem (two different fluids) Jon FLUENT 5 February 20, 2008 06:56
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Problem in Tutorial problem of fluent Phanindra FLUENT 5 April 17, 2007 09:57
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
