gamma-ReTheta turbulence model for predicting transitional flows |
July 1, 2016, 05:15 |
#101 |
Artur
Rep Power: 20 |
Hmm, good to know. I only used the gamma-ReTheta model in application to the T3 cases without pressure gradient and then switched to kkl. Since you mention Cl I assume you're running a case for a foil so it may be that things will be a bit different due to the pressure gradients. Anyhow, thanks for sharing!
July 1, 2016, 05:47 |
#102 | |
Rep Power: 10 |
kklomega model implemented in OF presents some iusses ho reported here
July 1, 2016, 05:51 |
#103 |
Artur
Rep Power: 20 |
Yup, seen that one. Thanks a lot for spreading the word around
July 1, 2016, 06:24 |
#104 | |
Rep Power: 10 |
July 1, 2016, 06:32 |
#105 |
Artur
Rep Power: 20 |
In truth, I stopped working on transition for a while but then when I came back to it I had to start getting things done pretty rapidly. By then I had switched to OpenFOAM 3 and had issues compiling the gamma Re theta model so just had to use the built-in one. I'm hoping to get a bit more time to compile the code under new OF soon though when I might go back to it since it seems slightly more robust.
July 1, 2016, 10:43 |
#106 |
Rep Power: 10 |
Might I ask you an advice? I told you that I have an O-Grid so I should use freestream bc for far field...but there is a bc for ReTheta for inlet attached with gammaReTheta in which header file I read:
Note In the event of reverse flow, a zero-gradient condition is applied So it means that I could apply it even for far field? I hypothesize this because in freestream header file I read: Description This boundary condition provides a free-stream condition. It is a 'mixed' condition derived from the \c inletOutlet condition, whereby the mode of operation switches between fixed (free stream) value and zero gradient based on the sign of the flux. |
July 2, 2016, 07:22 |
#107 |
Artur
Rep Power: 20 |
I would assume you can use that if it's been derived from the inletOutlet BC which works OK with o-grids. I haven't used that BC myself, in the past I would compute the inlet quantities myslef and apply a fixedValue at the inlet but it should be more straightforward with the dedicated BC.
July 4, 2016, 05:18 |
#108 |
Rep Power: 10 |
Thank you Artur but unfortunely my problems don't stop here. I'm performing unsteady simulation with PimpleFoam but I have very high residual of p that i can't able to reduce. How dou you valutate my fvSolution?
solvers { p { solver PCG; preconditioner DIC; tolerance 1e-04; relTol 0.05; } pFinal { $p; tolerance 1e-4; relTol 0; } U { solver smoothSolver; smoother GaussSeidel; preconditioner DILU; tolerance 1e-05; relTol 0.1; nSweeps 2; } "(gamma|ReThetatTilda|k)" { solver smoothSolver; smoother GaussSeidel; preconditioner DILU; tolerance 1e-05; relTol 0.1; nSweeps 2; } omega { $U tolerance 1e-6; relTol 0.1; } omegaFinal { $U tolerance 1e-7; relTol 0; } UFinal { $U; tolerance 1e-5; relTol 0; } "(ReThetatTilda|gamma|k)Final" { $U; tolerance 1e-6; relTol 0; } } PIMPLE { nOuterCorrectors 20; nCorrectors 2; nNonOrthogonalCorrectors 3; pRefCell 0; pRefValue 0; residualControl { "(p|U|k|ReThetatTilda|omega|gamma)" { tolerance 1e-5; relTol 1e-2; } } } potentialFlow { nNonOrthogonalCorrectors 10; } relaxationFactors { fields { p 0.3; } equations { U 0.5; k 0.5; ReThetatTilda 0.5; omega 0.5; gamma 0.5; } } |
July 4, 2016, 08:17 |
#109 |
Artur
Rep Power: 20 |
Had a quick look and nothing in particular strikes me as wrong. I'd be careful though with the underrelaxation factors you've set, they seem lower than what I'd go with myself. Another possibility is the time step being too large. I'm assuming you're happy with your mesh? Are you initialising your simulation using a steady-state solution or at least potentialFoam first? Otherwise hard to say. Good luck, A |
July 4, 2016, 12:33 |
#110 |
Rep Power: 10 |
my mesh has max non-orthogonality 88 with 171 non-ortho faces placed near airfoil. About initialization i don't have done anything. Might be non orthogonality of mesh the problem?
July 4, 2016, 13:27 |
#111 |
Artur
Rep Power: 20 |
Yes, 88 sounds quite high. I'd suggest running it with potentialFoam first, then simpleFoam with a standard k-omega SST turbulence model to make sure mesh and settings are ok. Then use the velocity fields from steady-state simulation to initialise the one you're really after. Also, probably best to continue this in a new thread under Running, soling & CFD since we've gone off topic (feel free to send me a private message with a link to the new thread if you end up opening it).
Peace, A |
July 6, 2016, 04:53 |
#112 | |
Rep Power: 10 |
The value for internal field, that is just an initialization, shouldn't be same of inlet calculated with (24)? And why the reason of 0.1 at inlet? |
July 6, 2016, 06:54 |
#113 |
Artur
Rep Power: 20 |
Not entirely sure what you're asking, here's the BC file I used for ReTheta: Code:
dimensions [0 0 0 0 0 0 0]; internalField uniform 1.574098e+02; boundaryField { flatPlate { type zeroGradient; } frontPlate { type symmetryPlane; } top { type symmetryPlane; } inlet { type fixedValue; value $internalField; } outlet { type zeroGradient; } } Hopefully this addresses your questions. All the best, A |
July 6, 2016, 07:03 |
#114 |
Rep Power: 10 |
If you see there is a file called initialConditions where the inlet value is 0.1
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.1 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ flowVelocity (5.4 0 0); pressure 0; turbulentKE 5.668704e-02; // Tu = 3.6% turbulentOmega 3.149280e+02; // mut/mu = 12 ReThetatTilda 0.1;//1.574098e+02; #inputMode merge // ************************************************** *********************** // |
July 6, 2016, 07:10 |
#115 |
Artur
Rep Power: 20 |
Oh, I see now. I must have forgotten to delete it when I was experimenting with stuff. Nonetheless, this value doesn't get used in the actual BC file since the inlet value gets specified explicitly. Sorry for the confusion.
A |
January 24, 2018, 22:56 |
Help Me
#116 |
ESI
Rep Power: 8 |
January 25, 2018, 10:23 |
#117 |
Klaus
Rep Power: 22 |
please describe the simulation you are planning (airfoil, Reynolds number, Tu...) and your setup problems. In general, it's a good idea to use a working case which uses a similar turbulence model as a starting point and make adjustments rather than creating a new setup from scratch. You could use a steady state (simpleFoam) case which uses e.g. kOmegaSST if you have one and you should look at the tutorials maybe there's a case using the model you want to use. To get an idea about calculating the model specific initial values (specific 0 folder content for gammaInt and ReThetat) read the academic papers describing the model: Langtry, R. B., & Menter, F. R. (2009). Correlation-based transition modeling for unstructured parallelized computational fluid dynamics codes. AIAA journal, 47(12), 2894-2906. Menter, F. R., Langtry, R., & Volker, S. (2006). Transition modelling for general purpose CFD codes. Flow, turbulence and combustion, 77(1-4), 277-303. Langtry, R. B. (2006). A correlation-based transition model using local variables for unstructured parallelized CFD codes. Phd. Thesis, Universität Stuttgart. Klaus Last edited by klausb; January 25, 2018 at 15:02. |
January 25, 2018, 20:38 |
#118 | |
ESI
Rep Power: 8 |
I am using KomegaSSTLM for my simulation. But I don't know the reason why my result incorrect? this is my case: I run the simulation for A-airfoil with inlet condition is M = 0.15,Re = 2.1e6, alpha =13.1,Tu = 0.1%,μ_t/μ =2. I calculate the coefficients: K =3/2(UI)^2 = 3/2 (51.9*0.1%)^2=0.00404; ω = ρ* k/μ*(μ_t/μ)^-1 ω = 1.225*0.00404/(1.846*10^-5)*(2)^-1=134.05; gamma I choose 1. gama = 1; Re_thetat = (1173.51-589.428*Tu+0.2196/(Tu^2))*F(λθ) if Tu<= 1.3; Re_thetat = 331.50*(Tu-0.5658)^-0.671*F(λθ) if Tu >1.3; F(λθ) =1-1(-12.986*λθ-123.66*λθ^2-405.689*λθ^3)*e^(Tu/1.5)^1.5 if λθ<=0; F(λθ) =1+0.275*(1-e^(-35.*λθ))*e^(Tu/0.5) if λθ>0; From this function: I choose λθ = 0 ( I not sure it is correct I only think Du/Ds = 0 Inferred λθ = 0) then I calculate Re_thetat = 1.365e+3. I have the coefficients: K =0.00404;ω =134.05,gamma = 1,Re_theta = 1.365e+3 this is the coefficient value for inlet condition. And Then I set up following the tutorial incompressible/simpleFoam/T3A. I change the geometry to A-airfoil and set up the value coefficient and I run it. The finally, I run with comment line "simpleFoam -postProcess -func 'wallShearStress' and paraFoam. In the paraview I load out the data in the surface top-Airfoil. I plot the wallshearstress following the x-axis. But my result incorrect. If you have experienced run with KomegaSSTLM for airfoil Please teache me. I really hope anyone who can help me resolve it. Thank you very much |
January 25, 2018, 22:09 |
#119 | |
ESI
Rep Power: 8 |
Could you teach me to set up on the airfoil with KomegaSSTLM turbulence. This is my set up: |
January 25, 2018, 22:13 |
#120 | |
ESI
Rep Power: 8 |
I want to plot the graph similar it. but I don't konw How to do it in paraview? https://www.cfd-online.com/Forums/me...re900-you2.jpg |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
Centrifugal Pump and Turbulence Model | Michiel | CFX | 12 | January 25, 2010 03:20 |
RSM & Transitional Flows!!! | Erika | FLUENT | 0 | March 31, 2006 10:56 |
Turbulence model | Herry | Phoenics | 1 | May 29, 2003 13:19 |
turbulent separated flows | Yin | Fidelity CFD | 9 | February 19, 2003 11:50 |
