how to extract vector from tensor ?
Old   March 2, 2011, 13:01
Default how to extract vector from tensor ?
Cyp
Cyprien
Cyp is on a distinguished road
Hi!
I would like to extract a vector from a tensor. I know one can recover a scalar from a tensor using T.xx() ; T.xy() ...
Do you know what can I do to recover the first column of my tensor ?
Best,
Cyp
Cyp is offline   Reply With Quote
Old   March 2, 2011, 15:11
Steven van Haren
stevenvanharen is on a distinguished road
Take a look at this util:
http://www.cfd-online.com/Forums/ope...9-utility.html
You should be able to edit this utility to output the first column of your tensor.
stevenvanharen is offline   Reply With Quote
Old   March 2, 2011, 17:03
Cyp
Cyprien
Hi Steve!
Thank you for your answer. I had a look at your code.
I tried this snippet :
        D1.component(tensor::XX) = U1x.component(vector::X);
        D1.component(tensor::YX) = U1x.component(vector::Y);
        D1.component(tensor::ZX) = U1x.component(vector::Z);
It compiles but my tensor D1 is not update with the U1x values.. Do you why I am wrong ?
Regards,
Cyp
Old   March 3, 2011, 04:14
Steven van Haren
Hard to say like this.
Can you post the entire code?
Old   March 3, 2011, 05:25
Cyp
Cyprien
Hi Steven!
Actually, this the piece of code
        fvVectorMatrix U1xEqn
            fvm::ddt(U1x)
          - fvm::laplacian(nu, U1x)
          + unitE*alpha*vector(1,0,0)
        solve(U1xEqn == -fvc::grad(p1x));
        // --- PISO loop
        for (int corr=0; corr<nCorr; corr++)
            volScalarField rU1xA = 1.0/U1xEqn.A();
//            rUA = 1.0/UEqn.A();
            U1x    = rU1xA*U1xEqn.H();
            phi_1x = (fvc::interpolate(U1x) & mesh.Sf())
                   + fvc::ddtPhiCorr(rU1xA, U1x, phi_1x);
            adjustPhi(phi_1x, U1x, p1x);
            for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
                fvScalarMatrix p1xEqn
                    fvm::laplacian(rU1xA, p1x) == fvc::div(phi_1x)
                p1xEqn.setReference(pRefCell, pRefValue);
                p1xEqn.solve();
                if (nonOrth == nNonOrthCorr)
                    phi_1x -= p1xEqn.flux();
            #include "continuityErrs.H"
            U1x -= rU1xA*fvc::grad(p1x);
            U1x.correctBoundaryConditions();
Where D1 is a volTensorField defined as:
    volTensorField D1
        IOobject
            "D1",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        mesh,
        dimensionedTensor("D1",dimensionSet(0,2,0,0,0),tensor::zero)
Old   March 3, 2011, 05:57
Steven van Haren
like this it works:
D1= tensor(1,0,0,0,0,0,0,0,0)*U1x.component(vector::X);
I know it looks a bit strange but at least it works
Old   March 3, 2011, 07:47
Cyp
Cyprien
Thank you for your answer..
in fact, it not really worked since when you write :
D1= tensor(0,0,0,1,0,0,0,0,0)*U1x.component(vector::Y);
The first instruction is not accounted for...
So, indeed I could do :
D1=
tensor(1,0,0,0,0,0,0,0,0)*U1x.component(vector::X) +
but it's not what I looked for....
extract information from sample during simulation for use duongquaphim OpenFOAM Programming & Development 0 January 10, 2011 13:51
How to modify the stress tensor of momentum eqns. Jason FLUENT 1 November 26, 2010 05:20
curvature correction term, material derivative of a tensor volker OpenFOAM Programming & Development 7 June 3, 2010 08:08
About deformation gradient tensor ZHANG Main CFD Forum 0 June 18, 2007 12:51
second invariant of rate-of-strain tensor Chun Min Chew Main CFD Forum 3 December 10, 2003 11:34
